Hi ,
I am unable to run the android mobile app test cases. I tried running the test case but got an error saying “Did not get confirmation UiAutomator2 deleteSession worked; Error was: Error: Trying to proxy a session command without session id”. And one more thing which i observed, when tried killing katalon tool from task manager and run the same test case, it worked for me several times. But how to get rid of this issue which i am facing very freequently. Please provide sol’n for this. Any help would be highly appreciated.
Anyone ,please provide solution. I am really stuck here, not able to countinue with test.
Try to clear cache your node.js
npm cache clean --force
Hi Creta, were you able to solve the problem? I am facing the exact same issue.
I am facing the same issue. @creta Is the issue resolved for you?
huynguyen Request your help. I am getting below error when I start executing test case from Katalon or try to record
“Root cause: org.openqa.selenium.SessionNotCreatedException: Unable to create a new remote session. Please check the server log for more details. Original error: An unknown server-side error occurred while processing the command. Original error: Error executing adbExec.”
Although I am able to see the device:
Hi @Neelesh_Singh,
Please show us the full message log?
@duyluong Below are are the logs:
08-19-2019 06:51:09 PM Test Cases/Verify APK from Local Appium
Elapsed time: 4m - 56.301s
Test Cases/Verify APK from Local Appium FAILED.
com.kms.katalon.core.exception.StepFailedException: Unable to start app at: ‘D:\Users\TestUser\Katalon Studio\SampleTestMobile01.prj\androidapp\APIDemos.apk’ (Root cause: org.openqa.selenium.SessionNotCreatedException: Unable to create a new remote session. Please check the server log for more details. Original error: An unknown server-side error occurred while processing the command. Original error: Error executing adbExec. Original error: ‘Command ‘D:\Users\TestUser\.katalon\tools\android_sdk\platform-tools\adb.exe -P 5037 -s emulator-5554 shell wm size’ timed out after 20000ms’; Stderr: ‘’; Code: ‘null’
Build info: version: ‘3.141.59’, revision: ‘e82be7d358’, time: ‘2018-11-14T08:25:53’
System info: host: ‘IP-C613ACF6’, ip: ‘172.16.0.166’, os.name: ‘Windows Server 2016’, os.arch: ‘amd64’, os.version: ‘10.0’, java.version: ‘1.8.0_181’
Driver info: driver.version: SwipeableAndroidDriver
remote stacktrace: UnknownError: An unknown server-side error occurred while processing the command. Original error: Error executing adbExec. Original error: ‘Command ‘D:\Users\TestUser\.katalon\tools\android_sdk\platform-tools\adb.exe -P 5037 -s emulator-5554 shell wm size’ timed out after 20000ms’; Stderr: ‘’; Code: ‘null’
at getResponseForW3CError (D:\Users\TestUser\AppData\Roaming\npm\node_modules\appium\node_modules\appium-base-driver\lib\protocol\errors.js:806:13)
at asyncHandler$ (D:\Users\TestUser\AppData\Roaming\npm\node_modules\appium\node_modules\appium-base-driver\lib\protocol\protocol.js:361:37)
at tryCatch (D:\Users\TestUser\AppData\Roaming\npm\node_modules\appium\node_modules\babel-runtime\regenerator\runtime.js:67:40)
at GeneratorFunctionPrototype.invoke [as _invoke] (D:\Users\TestUser\AppData\Roaming\npm\node_modules\appium\node_modules\babel-runtime\regenerator\runtime.js:315:22)
at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (D:\Users\TestUser\AppData\Roaming\npm\node_modules\appium\node_modules\babel-runtime\regenerator\runtime.js:100:21)
at GeneratorFunctionPrototype.invoke (D:\Users\TestUser\AppData\Roaming\npm\node_modules\appium\node_modules\babel-runtime\regenerator\runtime.js:136:37)
at io.appium.java_client.remote.AppiumCommandExecutor$1.createSession(AppiumCommandExecutor.java:208)
at io.appium.java_client.remote.AppiumCommandExecutor.createSession(AppiumCommandExecutor.java:217)
at io.appium.java_client.remote.AppiumCommandExecutor.execute(AppiumCommandExecutor.java:239)
at org.openqa.selenium.remote.RemoteWebDriver.execute(RemoteWebDriver.java:552)
at io.appium.java_client.DefaultGenericMobileDriver.execute(DefaultGenericMobileDriver.java:42)
at io.appium.java_client.AppiumDriver.execute(AppiumDriver.java:1)
at io.appium.java_client.android.AndroidDriver.execute(AndroidDriver.java:1)
at com.kms.katalon.core.appium.driver.SwipeableAndroidDriver.execute(SwipeableAndroidDriver.java:1)
at org.openqa.selenium.remote.RemoteWebDriver.startSession(RemoteWebDriver.java:213)
at org.openqa.selenium.remote.RemoteWebDriver.(RemoteWebDriver.java:131)
at io.appium.java_client.DefaultGenericMobileDriver.(DefaultGenericMobileDriver.java:38)
at io.appium.java_client.AppiumDriver.(AppiumDriver.java:84)
at io.appium.java_client.android.AndroidDriver.(AndroidDriver.java:85)
at com.kms.katalon.core.appium.driver.SwipeableAndroidDriver.(SwipeableAndroidDriver.java:24)
at com.kms.katalon.core.appium.driver.AppiumDriverManager.createMobileDriver(AppiumDriverManager.java:497)
at com.kms.katalon.core.appium.driver.AppiumDriverManager.createMobileDriver(AppiumDriverManager.java:479)
at com.kms.katalon.core.mobile.keyword.internal.MobileDriverFactory.startLocalMobileDriver(MobileDriverFactory.java:460)
at com.kms.katalon.core.mobile.keyword.internal.MobileDriverFactory.startMobileDriver(MobileDriverFactory.java:374)
at com.kms.katalon.core.mobile.keyword.builtin.StartApplicationKeyword$_startApplication_closure1.doCall(StartApplicationKeyword.groovy:49)
at com.kms.katalon.core.mobile.keyword.builtin.StartApplicationKeyword$_startApplication_closure1.call(StartApplicationKeyword.groovy)
at com.kms.katalon.core.mobile.keyword.internal.MobileKeywordMain.runKeyword(MobileKeywordMain.groovy:21)
at com.kms.katalon.core.mobile.keyword.builtin.StartApplicationKeyword.startApplication(StartApplicationKeyword.groovy:51)
at com.kms.katalon.core.mobile.keyword.builtin.StartApplicationKeyword.execute(StartApplicationKeyword.groovy:40)
at com.kms.katalon.core.keyword.internal.KeywordExecutor.executeKeywordForPlatform(KeywordExecutor.groovy:56)
at com.kms.katalon.core.mobile.keyword.MobileBuiltInKeywords.startApplication(MobileBuiltInKeywords.groovy:74)
at com.kms.katalon.core.mobile.keyword.MobileBuiltInKeywords$startApplication.call(Unknown Source)
at Verify APK from Local Appium.run(Verify APK from Local Appium:18)
at com.kms.katalon.core.main.TestCaseExecutor.runScript(TestCaseExecutor.java:337)
at com.kms.katalon.core.main.TestCaseExecutor.doExecute(TestCaseExecutor.java:328)
at com.kms.katalon.core.main.TestCaseExecutor.processExecutionPhase(TestCaseExecutor.java:307)
at com.kms.katalon.core.main.TestCaseExecutor.accessMainPhase(TestCaseExecutor.java:299)
at com.kms.katalon.core.main.TestCaseExecutor.execute(TestCaseExecutor.java:233)
at com.kms.katalon.core.main.TestCaseMain.runTestCase(TestCaseMain.java:114)
at com.kms.katalon.core.main.TestCaseMain$runTestCase$0.call(Unknown Source)
at TempTestCase1566233463550.run(TempTestCase1566233463550.groovy:21)
Caused by: java.lang.reflect.InvocationTargetException
at io.appium.java_client.remote.AppiumCommandExecutor$1.createSession(AppiumCommandExecutor.java:186)
at Script1565811041982.run(Script1565811041982.groovy:18)
… 10 more
Caused by: org.openqa.selenium.WebDriverException: An unknown server-side error occurred while processing the command. Original error: Error executing adbExec. Original error: ‘Command ‘D:\Users\TestUser\.katalon\tools\android_sdk\platform-tools\adb.exe -P 5037 -s emulator-5554 shell wm size’ timed out after 20000ms’; Stderr: ‘’; Code: ‘null’
at org.openqa.selenium.remote.W3CHandshakeResponse.lambda$errorHandler$0(W3CHandshakeResponse.java:62)
at org.openqa.selenium.remote.HandshakeResponse.lambda$getResponseFunction$0(HandshakeResponse.java:30)
at org.openqa.selenium.remote.ProtocolHandshake.lambda$createSession$0(ProtocolHandshake.java:126)
at org.openqa.selenium.remote.ProtocolHandshake.createSession(ProtocolHandshake.java:128)
… 37 more
at com.kms.katalon.core.keyword.internal.KeywordMain.stepFailed(KeywordMain.groovy:50)
at com.kms.katalon.core.mobile.keyword.internal.MobileKeywordMain.stepFailed(MobileKeywordMain.groovy:40)
at com.kms.katalon.core.mobile.keyword.internal.MobileKeywordMain.runKeyword(MobileKeywordMain.groovy:23)
Caused by: org.openqa.selenium.SessionNotCreatedException: Unable to create a new remote session. Please check the server log for more details. Original error: An unknown server-side error occurred while processing the command. Original error: Error executing adbExec. Original error: ‘Command ‘D:\Users\TestUser\.katalon\tools\android_sdk\platform-tools\adb.exe -P 5037 -s emulator-5554 shell wm size’ timed out after 20000ms’; Stderr: ‘’; Code: ‘null’
… 16 more
… 10 more
… 10 more
Hi @Neelesh_Singh,
The error log showed Appium could not start this command:
Please run the command in terminal and show us the result.
08-20-2019 02:01:25 PM Test Cases/TC02_Verify Last Items In List
Elapsed time: 1m - 43.596s
Test Cases/TC02_Verify Last Items In List FAILED.
com.kms.katalon.core.exception.StepFailedException: Unable to start app at: ‘C:\Users\NES\Katalon Studio\MobileTestNewKatalonVersion\androidapp\APIDemos.apk’ (Root cause: org.openqa.selenium.SessionNotCreatedException: Unable to create a new remote session. Please check the server log for more details. Original error: An unknown server-side error occurred while processing the command. Original error: Error executing adbExec. Original error: ‘Command ‘C:\Users\NES\.katalon\tools\android_sdk\platform-tools\adb.exe -P 5037 -s emulator-5554 install C:\Users\NES\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-server\apks\appium-uiautomator2-server-v1.12.0.apk’ timed out after 20000ms’; Stderr: ‘’; Code: ‘null’
System info: host: ‘LAP03227’, ip: ‘10.30.10.237’, os.name: ‘Windows 7’, os.arch: ‘amd64’, os.version: ‘6.1’, java.version: ‘1.8.0_181’
remote stacktrace: UnknownError: An unknown server-side error occurred while processing the command. Original error: Error executing adbExec. Original error: ‘Command ‘C:\Users\NES\.katalon\tools\android_sdk\platform-tools\adb.exe -P 5037 -s emulator-5554 install C:\Users\NES\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-server\apks\appium-uiautomator2-server-v1.12.0.apk’ timed out after 20000ms’; Stderr: ‘’; Code: ‘null’
at getResponseForW3CError (C:\Users\NES\AppData\Roaming\npm\node_modules\appium\node_modules\appium-base-driver\lib\protocol\errors.js:806:13)
at asyncHandler$ (C:\Users\NES\AppData\Roaming\npm\node_modules\appium\node_modules\appium-base-driver\lib\protocol\protocol.js:361:37)
at tryCatch (C:\Users\NES\AppData\Roaming\npm\node_modules\appium\node_modules\babel-runtime\regenerator\runtime.js:67:40)
at GeneratorFunctionPrototype.invoke [as _invoke] (C:\Users\NES\AppData\Roaming\npm\node_modules\appium\node_modules\babel-runtime\regenerator\runtime.js:315:22)
at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (C:\Users\NES\AppData\Roaming\npm\node_modules\appium\node_modules\babel-runtime\regenerator\runtime.js:100:21)
at GeneratorFunctionPrototype.invoke (C:\Users\NES\AppData\Roaming\npm\node_modules\appium\node_modules\babel-runtime\regenerator\runtime.js:136:37)
at
at TC02_Verify Last Items In List.run(TC02_Verify Last Items In List:16)
at com.kms.katalon.core.main.TestCaseMain.runTestCase(TestCaseMain.java:105)
at TempTestCase1566302482376.run(TempTestCase1566302482376.groovy:21)
at Script1482674146196.run(Script1482674146196.groovy:16)
… 11 more
Caused by: org.openqa.selenium.WebDriverException: An unknown server-side error occurred while processing the command. Original error: Error executing adbExec. Original error: ‘Command ‘C:\Users\NES\.katalon\tools\android_sdk\platform-tools\adb.exe -P 5037 -s emulator-5554 install C:\Users\NES\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-server\apks\appium-uiautomator2-server-v1.12.0.apk’ timed out after 20000ms’; Stderr: ‘’; Code: ‘null’
at
… 38 more
Caused by: org.openqa.selenium.SessionNotCreatedException: Unable to create a new remote session. Please check the server log for more details. Original error: An unknown server-side error occurred while processing the command. Original error: Error executing adbExec. Original error: ‘Command ‘C:\Users\NES\.katalon\tools\android_sdk\platform-tools\adb.exe -P 5037 -s emulator-5554 install C:\Users\NES\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-server\apks\appium-uiautomator2-server-v1.12.0.apk’ timed out after 20000ms’; Stderr: ‘’; Code: ‘null’
at
… 17 more
… 11 more
at
… 11 more
@duyluong : Logs above
@duyluong Ignore the above message:
Below is fresh logs:
C:\Windows\system32>D:\Users\TestUser.katalon\tools\android_sdk\platform-tools\adb.exe -P 5037 -s emulator-5554 shell am start -W -n
usage: am [subcommand] [options]
usage: am start [-D] [-W] [-P ] [–start-profiler ]
[–sampling INTERVAL] [-R COUNT] [-S] [–opengl-trace]
[–user <USER_ID> | current]
am startservice [–user <USER_ID> | current]
am stopservice [–user <USER_ID> | current]
am force-stop [–user <USER_ID> | all | current]
am kill [–user <USER_ID> | all | current]
am kill-all
am broadcast [–user <USER_ID> | all | current]
am instrument [-r] [-e ] [-p ] [-w]
[–no-window-animation] [–abi ]
am profile start [–user <USER_ID> current] [–sampling INTERVAL]
am profile stop [–user <USER_ID> current] []
am dumpheap [–user <USER_ID> current] [-n]
am set-debug-app [-w] [–persistent]
am clear-debug-app
am set-watch-heap
am clear-watch-heap
am monitor [–gdb ]
am hang [–allow-restart]
am restart
am idle-maintenance
am screen-compat [on|off]
am package-importance
am to-uri [INTENT]
am to-intent-uri [INTENT]
am to-app-uri [INTENT]
am switch-user <USER_ID>
am start-user <USER_ID>
am stop-user [-w] <USER_ID>
am stack start <DISPLAY_ID>
am stack movetask <TASK_ID> <STACK_ID> [true|false]
am stack resize <STACK_ID> <LEFT,TOP,RIGHT,BOTTOM>
am stack split <STACK_ID> <v|h> [INTENT]
am stack list
am stack info <STACK_ID>
am task lock <TASK_ID>
am task lock stop
am task resizeable <TASK_ID> [true|false]
am task resize <TASK_ID> <LEFT,TOP,RIGHT,BOTTOM>
am get-config
am set-inactive [–user <USER_ID>] true|false
am get-inactive [–user <USER_ID>]
am send-trim-memory [–user <USER_ID>]
[HIDDEN|RUNNING_MODERATE|BACKGROUND|RUNNING_LOW|MODERATE|RUNNING_CRITICAL|COMPLETE]
am start: start an Activity. Options are:
-D: enable debugging
-W: wait for launch to complete
–start-profiler : start profiler and send results to
–sampling INTERVAL: use sample profiling with INTERVAL microseconds
between samples (use with --start-profiler)
-P : like above, but profiling stops when app goes idle
-R: repeat the activity launch times. Prior to each repeat,
the top activity will be finished.
-S: force stop the target app before starting the activity
–opengl-trace: enable tracing of OpenGL functions
–user <USER_ID> | current: Specify which user to run as; if not
specified then run as the current user.
am startservice: start a Service. Options are:
am stopservice: stop a Service. Options are:
am force-stop: force stop everything associated with .
–user <USER_ID> | all | current: Specify user to force stop;
all users if not specified.
am kill: Kill all processes associated with . Only kills.
processes that are safe to kill – that is, will not impact the user
experience.
–user <USER_ID> | all | current: Specify user whose processes to kill;
am kill-all: Kill all background processes.
am broadcast: send a broadcast Intent. Options are:
–user <USER_ID> | all | current: Specify which user to send to; if not
specified then send to all users.
–receiver-permission : Require receiver to hold permission.
am instrument: start an Instrumentation. Typically this target
is the form <TEST_PACKAGE>/<RUNNER_CLASS>. Options are:
-r: print raw results (otherwise decode REPORT_KEY_STREAMRESULT). Use with
[-e perf true] to generate raw output for performance measurements.
-e : set argument to . For test runners a
common form is [-e <testrunner_flag> [,…]].
-p : write profiling data to
-w: wait for instrumentation to finish before returning. Required for
test runners.
–user <USER_ID> | current: Specify user instrumentation runs in;
current user if not specified.
–no-window-animation: turn off window animations while running.
–abi : Launch the instrumented process with the selected ABI.
This assumes that the process supports the selected ABI.
am profile: start and stop profiler on a process. The given argument
may be either a process name or pid. Options are:
–user <USER_ID> | current: When supplying a process name,
specify user of process to profile; uses current user if not specified.
am dumpheap: dump the heap of a process. The given argument may
-n: dump native heap instead of managed heap
specify user of process to dump; uses current user if not specified.
am set-debug-app: set application to debug. Options are:
-w: wait for debugger when application starts
–persistent: retain this value
am clear-debug-app: clear the previously set-debug-app.
am set-watch-heap: start monitoring pss size of , if it is at or
above then a heap dump is collected for the user to report
am clear-watch-heap: clear the previously set-watch-heap.
am bug-report: request bug report generation; will launch UI
when done to select where it should be delivered.
am monitor: start monitoring for crashes or ANRs.
–gdb: start gdbserv on the given port at crash/ANR
am hang: hang the system.
–allow-restart: allow watchdog to perform normal system restart
am restart: restart the user-space system.
am idle-maintenance: perform idle maintenance now.
am screen-compat: control screen compatibility mode of .
am package-importance: print current importance of .
am to-uri: print the given Intent specification as a URI.
am to-intent-uri: print the given Intent specification as an intent: URI.
am to-app-uri: print the given Intent specification as an android-app: URI.
am switch-user: switch to put USER_ID in the foreground, starting
execution of that user if it is currently stopped.
am start-user: start USER_ID in background if it is currently stopped,
use switch-user if you want to start the user in foreground.
am stop-user: stop execution of USER_ID, not allowing it to run any
code until a later explicit start or switch to it.
-w: wait for stop-user to complete.
am stack start: start a new activity on <DISPLAY_ID> using .
am stack movetask: move <TASK_ID> from its current stack to the top (true) or bottom (false) of <STACK_ID>.
am stack resize: change <STACK_ID> size and position to <LEFT,TOP,RIGHT,BOTTOM>.
am stack split: split <STACK_ID> into 2 stacks ertically or orizontally
starting the new stack with [INTENT] if specified. If [INTENT] isn’t
specified and the current stack has more than one task, then the top task
of the current task will be moved to the new stack. Command will also force
all current tasks in both stacks to be resizeable.
am stack list: list all of the activity stacks and their sizes.
am stack info: display the information about activity stack <STACK_ID>.
am task lock: bring <TASK_ID> to the front and don’t allow other tasks to run.
am task lock stop: end the current task lock.
am task resizeable: change if <TASK_ID> is resizeable (true) or not (false).
am task resize: makes sure <TASK_ID> is in a stack with the specified bounds.
Forces the task to be resizeable and creates a stack if no existing stack
has the specified bounds.
am get-config: retrieve the configuration and any recent configurations
of the device.
am set-inactive: sets the inactive state of an app.
am get-inactive: returns the inactive state of an app.
am send-trim-memory: Send a memory trim event to a .
specifications include these flags and arguments:
[-a ] [-d <DATA_URI>] [-t <MIME_TYPE>]
[-c [-c ] …]
[-e|–es <EXTRA_KEY> <EXTRA_STRING_VALUE> …]
[–esn <EXTRA_KEY> …]
[–ez <EXTRA_KEY> <EXTRA_BOOLEAN_VALUE> …]
[–ei <EXTRA_KEY> <EXTRA_INT_VALUE> …]
[–el <EXTRA_KEY> <EXTRA_LONG_VALUE> …]
[–ef <EXTRA_KEY> <EXTRA_FLOAT_VALUE> …]
[–eu <EXTRA_KEY> <EXTRA_URI_VALUE> …]
[–ecn <EXTRA_KEY> <EXTRA_COMPONENT_NAME_VALUE>]
[–eia <EXTRA_KEY> <EXTRA_INT_VALUE>[,<EXTRA_INT_VALUE…]]
(mutiple extras passed as Integer[])
[–eial <EXTRA_KEY> <EXTRA_INT_VALUE>[,<EXTRA_INT_VALUE…]]
(mutiple extras passed as List)
[–ela <EXTRA_KEY> <EXTRA_LONG_VALUE>[,<EXTRA_LONG_VALUE…]]
(mutiple extras passed as Long[])
[–elal <EXTRA_KEY> <EXTRA_LONG_VALUE>[,<EXTRA_LONG_VALUE…]]
[–efa <EXTRA_KEY> <EXTRA_FLOAT_VALUE>[,<EXTRA_FLOAT_VALUE…]]
(mutiple extras passed as Float[])
[–efal <EXTRA_KEY> <EXTRA_FLOAT_VALUE>[,<EXTRA_FLOAT_VALUE…]]
[–esa <EXTRA_KEY> <EXTRA_STRING_VALUE>[,<EXTRA_STRING_VALUE…]]
(mutiple extras passed as String[]; to embed a comma into a string,
escape it using “,”)
[–esal <EXTRA_KEY> <EXTRA_STRING_VALUE>[,<EXTRA_STRING_VALUE…]]
(mutiple extras passed as List; to embed a comma into a string,
[–grant-read-uri-permission] [–grant-write-uri-permission]
[–grant-persistable-uri-permission] [–grant-prefix-uri-permission]
[–debug-log-resolution] [–exclude-stopped-packages]
[–include-stopped-packages]
[–activity-brought-to-front] [–activity-clear-top]
[–activity-clear-when-task-reset] [–activity-exclude-from-recents]
[–activity-launched-from-history] [–activity-multiple-task]
[–activity-no-animation] [–activity-no-history]
[–activity-no-user-action] [–activity-previous-is-top]
[–activity-reorder-to-front] [–activity-reset-task-if-needed]
[–activity-single-top] [–activity-clear-task]
[–activity-task-on-home]
[–receiver-registered-only] [–receiver-replace-pending]
[–selector]
Error: Argument expected after “-n”
