Hi guys, I wonder if I can execute a custom keyword only when all the test cases have passed after running the Suit. I tried to use the following listener to get the content of the suit. But my problem was that “COMPLETE” state is when all cases have been executed (even if they were passed or failed)
@AfterTestSuite def AfterTestSuite(TestSuiteContext testSuiteContext) { if(testSuiteContext.getStatus()=='COMPLETE'){ CustomKeywords.'lemonbrew.GlobalVariableUpdater.increaseEmailVariable'("Agent", "RealtorEmail") } }
So I tried to perform the above Listener receiving the context of test cases but I’m not sure If this is the correct way to do it
@AfterTestSuite def IncreaseGlobalVariableEmail(TestCaseContext testCaseContext) { String suitStatus List testcases= testCaseContext.testCaseStatus for(TestCaseContext testcase in testcases) { if(testcase =="FAILED") suitStatus= "FAILED" } if (suitStatus!="FAILED"){ CustomKeywords.'lemonbrew.GlobalVariableUpdater.increaseEmailVariable'("Agent", "RealtorEmail") } }
Results of a suit with only 1 test failed:
Console
2019-11-28 13:29:37.220 INFO c.k.katalon.core.main.TestSuiteExecutor - START Test Suites/SUIT Create an Agent
2019-11-28 13:29:37.264 INFO c.k.katalon.core.main.TestSuiteExecutor - hostName = rodri - DESKTOP-GVDDC6C
2019-11-28 13:29:37.266 INFO c.k.katalon.core.main.TestSuiteExecutor - os = Windows 10 64bit
2019-11-28 13:29:37.266 INFO c.k.katalon.core.main.TestSuiteExecutor - hostAddress = 192.168.1.13
2019-11-28 13:29:37.268 INFO c.k.katalon.core.main.TestSuiteExecutor - katalonVersion = 6.3.3.11
2019-11-28 13:29:37.293 INFO com.kms.katalon.core.util.KeywordUtil - This Katalon Studio version has been deprecated. Please upgrade Katalon Studio to the latest version.
2019-11-28 13:29:37.513 INFO c.k.katalon.core.main.TestCaseExecutor - --------------------
2019-11-28 13:29:37.513 INFO c.k.katalon.core.main.TestCaseExecutor - START Test Cases/Create an Agent flow/3. Sign in
2019-11-28 13:29:37.796 DEBUG testcase.3. Sign in - 1: openBrowser(“”)
2019-11-28 13:29:38.012 INFO c.k.k.core.webui.driver.DriverFactory - Starting ‘Chrome’ driver
nov 28, 2019 1:29:38 PM org.openqa.selenium.remote.DesiredCapabilities chrome
INFORMACIÓN: Using new ChromeOptions() is preferred to DesiredCapabilities.chrome()
2019-11-28 13:29:38.065 INFO c.k.k.core.webui.driver.DriverFactory - Action delay is set to 0 seconds
Starting ChromeDriver 78.0.3904.70 (edb9c9f3de0247fd912a77b7f6cae7447f6d3ad5-refs/branch-heads/3904@{#800}) on port 38043
Only local connections are allowed.
Please protect ports used by ChromeDriver and related test frameworks to prevent access by malicious code.
nov 28, 2019 1:29:41 PM org.openqa.selenium.remote.ProtocolHandshake createSession
INFORMACIÓN: Detected dialect: W3C
2019-11-28 13:29:41.174 INFO c.k.k.core.webui.driver.DriverFactory - sessionId = bacd561267f03f7e5de56d5224781a24
2019-11-28 13:29:41.190 INFO c.k.k.core.webui.driver.DriverFactory - browser = Chrome 78.0.3904.108
2019-11-28 13:29:41.191 INFO c.k.k.core.webui.driver.DriverFactory - platform = Windows 10
2019-11-28 13:29:41.191 INFO c.k.k.core.webui.driver.DriverFactory - seleniumVersion = 3.141.59
2019-11-28 13:29:41.192 INFO c.k.k.core.webui.driver.DriverFactory - proxyInformation = ProxyInformation{proxyOption=NO_PROXY, proxyServerType=HTTP, password=, proxyServerAddress=, proxyServerPort=0}
2019-11-28 13:29:41.193 DEBUG testcase.3. Sign in - 2: navigateToUrl(“https://dev.lemonbrew.com/”)
2019-11-28 13:29:44.959 DEBUG testcase.3. Sign in - 3: setText(findTestObject(“Page_LemonBrew HomePage/input_Username”), RealtorEmail)
2019-11-28 13:29:46.570 DEBUG testcase.3. Sign in - 4: setText(findTestObject(“Page_LemonBrew HomePage/input_password”), Password)
2019-11-28 13:29:46.785 DEBUG testcase.3. Sign in - 5: click(findTestObject(“Page_LemonBrew HomePage/button_LOG IN”))
2019-11-28 13:29:46.971 DEBUG testcase.3. Sign in - 6: waitForPageLoad(5)
2019-11-28 13:29:47.080 DEBUG testcase.3. Sign in - 7: verifyElementPresent(findTestObject(“Object Repository/Page_DocuSign/div_Profile realtor”), 4, STOP_ON_FAILURE)
2019-11-28 13:29:51.252 INFO c.k.k.c.webui.common.WebUiCommonHelper - Unable to find the element located by ‘By.cssSelector: div [class=“container realtor-profile-tabbed”]’. Please recheck the objects properties to make sure the desired element is located.
2019-11-28 13:29:51.589 ERROR c.k.k.core.keyword.internal.KeywordMain -
com.kms.katalon.core.webui.exception.WebElementNotFoundException: Web element with id: ‘Object Repository/Page_DocuSign/div_Profile realtor’ located by ‘By.cssSelector: div [class=“container realtor-profile-tabbed”]’ not found (Root cause: com.kms.katalon.core.exception.StepFailedException: com.kms.katalon.core.webui.exception.WebElementNotFoundException: Web element with id: ‘Object Repository/Page_DocuSign/div_Profile realtor’ located by ‘By.cssSelector: div [class=“container realtor-profile-tabbed”]’ not found
at com.kms.katalon.core.webui.keyword.internal.WebUIKeywordMain.stepFailed(WebUIKeywordMain.groovy:64)
at com.kms.katalon.core.webui.keyword.builtin.VerifyElementPresentKeyword$_verifyElementPresent_closure1.doCall(VerifyElementPresentKeyword.groovy:85)
at com.kms.katalon.core.webui.keyword.builtin.VerifyElementPresentKeyword$_verifyElementPresent_closure1.call(VerifyElementPresentKeyword.groovy)
at com.kms.katalon.core.webui.keyword.internal.WebUIKeywordMain.runKeyword(WebUIKeywordMain.groovy:20)
at com.kms.katalon.core.webui.keyword.builtin.VerifyElementPresentKeyword.verifyElementPresent(VerifyElementPresentKeyword.groovy:92)
at com.kms.katalon.core.webui.keyword.builtin.VerifyElementPresentKeyword.execute(VerifyElementPresentKeyword.groovy:68)
at com.kms.katalon.core.keyword.internal.KeywordExecutor.executeKeywordForPlatform(KeywordExecutor.groovy:56)
at com.kms.katalon.core.webui.keyword.WebUiBuiltInKeywords.verifyElementPresent(WebUiBuiltInKeywords.groovy:1418)
at com.kms.katalon.core.webui.keyword.WebUiBuiltInKeywords$verifyElementPresent$4.call(Unknown Source)
at 3. Sign in.run(3. Sign in:31)
at com.kms.katalon.core.main.TestCaseExecutor.runScript(TestCaseExecutor.java:337)
at com.kms.katalon.core.main.TestCaseExecutor.doExecute(TestCaseExecutor.java:328)
at com.kms.katalon.core.main.TestCaseExecutor.processExecutionPhase(TestCaseExecutor.java:307)
at com.kms.katalon.core.main.TestCaseExecutor.accessMainPhase(TestCaseExecutor.java:299)
at com.kms.katalon.core.main.TestCaseExecutor.execute(TestCaseExecutor.java:233)
at com.kms.katalon.core.main.TestSuiteExecutor.accessTestCaseMainPhase(TestSuiteExecutor.java:169)
at com.kms.katalon.core.main.TestSuiteExecutor.accessTestSuiteMainPhase(TestSuiteExecutor.java:142)
at com.kms.katalon.core.main.TestSuiteExecutor.execute(TestSuiteExecutor.java:91)
at com.kms.katalon.core.main.TestCaseMain.startTestSuite(TestCaseMain.java:157)
at com.kms.katalon.core.main.TestCaseMain$startTestSuite$0.call(Unknown Source)
at TempTestSuite1574958571198.run(TempTestSuite1574958571198.groovy:35)
2019-11-28 13:29:51.894 ERROR c.k.k.core.keyword.internal.KeywordMain -
Unable to verify object ‘Object Repository/Page_DocuSign/div_Profile realtor’ is present (Root cause: com.kms.katalon.core.exception.StepFailedException: Unable to verify object ‘Object Repository/Page_DocuSign/div_Profile realtor’ is present
at com.kms.katalon.core.webui.keyword.internal.WebUIKeywordMain.runKeyword(WebUIKeywordMain.groovy:26)
Caused by: com.kms.katalon.core.exception.StepFailedException: com.kms.katalon.core.webui.exception.WebElementNotFoundException: Web element with id: ‘Object Repository/Page_DocuSign/div_Profile realtor’ located by ‘By.cssSelector: div [class=“container realtor-profile-tabbed”]’ not found
… 19 more
2019-11-28 13:29:51.896 ERROR c.k.katalon.core.main.TestCaseExecutor -
Test Cases/Create an Agent flow/3. Sign in FAILED.
… 19 more
2019-11-28 13:29:51.899 INFO c.k.katalon.core.main.TestCaseExecutor - END Test Cases/Create an Agent flow/3. Sign in
2019-11-28 13:29:51.906 ERROR c.k.k.core.context.internal.TestHooker -
java.lang.NullPointerException: Cannot get property ‘testCaseStatus’ on null object
2019-11-28 13:29:51.907 INFO com.kms.katalon.core.util.KeywordUtil - This Katalon Studio version has been deprecated. Please upgrade Katalon Studio to the latest version.
2019-11-28 13:29:52.023 INFO com.kms.katalon.core.util.KeywordUtil - Start generating HTML report folder at: C:\Users\rodri\Documents\Lemonbrew-QA\Reports\20191128_132931\SUIT Create an Agent\20191128_132931…
2019-11-28 13:29:52.430 INFO com.kms.katalon.core.util.KeywordUtil - HTML report generated
2019-11-28 13:29:52.430 INFO com.kms.katalon.core.util.KeywordUtil - Start generating CSV report folder at: C:\Users\rodri\Documents\Lemonbrew-QA\Reports\20191128_132931\SUIT Create an Agent\20191128_132931…
2019-11-28 13:29:52.448 INFO com.kms.katalon.core.util.KeywordUtil - CSV report generated
2019-11-28 13:29:52.448 INFO com.kms.katalon.core.util.KeywordUtil - Start generating JUnit report folder at: C:\Users\rodri\Documents\Lemonbrew-QA\Reports\20191128_132931\SUIT Create an Agent\20191128_132931…
2019-11-28 13:29:52.556 INFO com.kms.katalon.core.util.KeywordUtil - JUnit report generated
2019-11-28 13:29:53.252 INFO c.k.katalon.core.main.TestSuiteExecutor - --------------------
2019-11-28 13:29:53.252 INFO c.k.katalon.core.main.TestSuiteExecutor - END Test Suites/SUIT Create an Agent
2019-11-28 13:29:53.252 INFO c.k.katalon.core.main.TestSuiteExecutor - ====================
Any ideas of how I can code my listener? I don’t have to many experiences with development so I’m not sure if that is the correct way to bring and store the status from all test cases inside my suit
