How to get test case status at TearDownTestCase method
Hello Community
At the test suite level, we have TearDownTestCase method
This method do not accept any parameter of type TestCaseContext i guess
is it possible to get the test case status here .? whether testcase was success or failure etc ?
just like the below exposed built in @AfterTestCase method in the TestListener class
@AfterTestCase
def sampleAfterTestCase(TestCaseContext testCaseContext) {
     def testCaseStatus = testCaseContext.getTestCaseStatus();
     println testCaseStatus }
Thank you
Hello @kazurayam
any idea on this
appreciate if you can take a look at this
Warm Regards
Musaffir
I do not understand what you want.
Please share your code, together with execution log or compilation error message you got.
I am trying to figure out how can i get the test case execution status whether it has passed or failed programatically.
The objective is, if a test case has failed i will need to do some test cleanup before the next test case gets triggered.
ideally this can be done in the @AfterTestCase method
This method in the listener provides the parameter of type TestCaseContext
but at the test suite level, do we have any such ?
I do not understand this sentence. Please elaborate it. What do you hope to have?
At the test suite level, we have the script mode rite
Please open any test suite and click on Script mode, where you see setupTestCase() , tearDownTestCase() methods no ?
it runs before and after of every testcase
can we know the corresponding test case status here ?
I found a Test Suite has the following code in the script mode tab.
import ...
@SetUp(skipped = true) // Please change skipped to be false to activate this method.
def setUp() {
	// Put your code here.
@TearDown(skipped = true) // Please change skipped to be false to activate this method.
def tearDown() {
@SetupTestCase(skipped = true) // Please change skipped to be false to activate this method.
def setupTestCase() {
@TearDownTestCase(skipped = true) // Please change skipped to be false to activate this method.
def tearDownTestCase() {
You wrote:
Then, do you want to rewrite the above script to be the following ? (please find TestCaseContext object as arguments):
import ...
def setUp(TestSuiteContext testSuiteContext) {
def tearDown(TestSuiteContext testSuiteContext) {
def setupTestCase(TestCaseContext testCaseContext) {
def tearDownTestCase(TestCaseContext testCaseContext) {
Yeah
It do not support this at suite level rite ?
testCaseContext is retrieved here as Null
In each indivisual Test Suite, no.
But in a TestListener, you can implement what you want.
Then why not you do:
import com.kms.katalon.core.annotation.AfterTestCase
import com.kms.katalon.core.context.TestCaseContext
class MusaffirTestListener {
	 * Executes after every test case ends.
	 * @param testCaseContext related information of the executed test case.
	@AfterTestCase
		if (testCaseContext.getTestCaseStatus() == 'FAILED') {
			// do whatever clean ups
in that case, the test listener will be applicable to all test suites rite.
for each test suite i will have specific needs. i will have specific things need to do when a testcase is failed.
So doing this at test listener looks not feasible to me
Do you think we can do something here ?
Should we submit a feature request?
Warm Regards,
have you tried to set skipped = false?
Why not you write:
    @AfterTestSuite
    def afterTestSuite(TestSuiteContext testSuiteContext) {
        switch (testSuiteContext.getTestSuiteName()) {
            case 'Orange':
                // do something specific for Orange
                break
            case 'Apple':
                // do something specific for Apple
                break
In this document
https://docs.katalon.com/katalon-studio/new/version-52.html#mobile-testing
you can read a description by Katalon Team saying
Test Listeners (Test Hooks)
Introducing Test Hooks feature in Katalon Studio version 5.2 to support users extend testing flows. Test Hooks are events binding that represent automation logic and will be executed once the condition is matched.
Prior to v5.2 there wasn’t TestListener. All we had was @SetUp/@TearDown-annotated method of each indivisula TestCases and TestSuites. Why Katalon Team added TestListener? Anything unsatisfactory with @SetUp/@TearDown-annotated methods? — Yes, there was. The API of @SetUp/@TearDown-annotated methods did not have the context arguments — TestCaseContext and TestSuiteContext. Therefore, I guess, Katalon Team decided to introduce a new concept of TestListener.
I personally always use TestListeners; I never use @SetUp/@TearDown-annotated method of each indivisula TestCases and TestSuites
@musaffir.puthukudi
I would recommend to you to forget @SetUp/@TearDown-annotated methods, and look at TestListener.
Thank you so much @kazurayam for taking time to look at it and for writing these.
I get this point , how ever i still feel like some thing is lagging at the tool end on this perspective.
TestListener would be something I like not to touch often, i.e if we go with the above approach, when ever we have a new suite, the TestListener class would need to be modified to handle the clean up script which required for the respective suite, as TestListener is applicable to all the suites in the project.
If I could write an abstract method in TestListener and if I have the flexibility of completing that abstract method in my Test suite, I would have been more happier here. So it becomes responsibility of individual suite developer to handle such clean up scripts as well and do not have to touch the TestListener.
Your thoughts ?
Let me show you one of my “TestListener” as an example:
As you can see, this VTListener applies the Composittion pattern. It has an instance of other class VisualTestingListenerImpl which implements some lenghy business logic. An instance of the VTListener class delegates the VisualTestingListernerImpl object to do every meaningful stuff. The code of VTListener class is very short. Once I wrote the VTListener class, I have rarely touched it and will not in future.
It is completely up to you how to design a TestListener implementation. It is just a plain old Groovy class with some annotations (@BeforeTestSuite, @AfterTestSuite, @BeforeTestCase, @AfterTestSuite). You have 100% of freedom how to design it.
For example, if I want to, I can move my com.kazurayam.visualtesting.VisualTestingListenerImpl class out of Katalon Studio project, and host it in a seperated Eclipse/Gradle project. There I would further develop the code, create a jar file, and bring the jar file into the Drivers folder of multiple Katalon Studo projects. I mean, I can share a single implementation of TestListener in multiple Katalon Studio projects. Flexible enough, isn’t it?
Can you please tell me what problem you were trying to solve with above approach ?
I think it will help me knowing it :grinning:
Finally I understand what you want. Provided that your Katalon Studio project is shared by your team of developers, you want to make development of clean up scripts to be the responsibility of individual suite developers, am I right?
I think it is an unique idea. I have never thought of it.
With this interest in mind, the centralized approach of TestListener would not fit to your idea. I suppose that Katalon team does not share your idea. You should raise a feature request and wait for their response.
sure @kazurayam
Really appreciate you spending time on this discussion
Have a great day ahead :grinning:
Thank you also for your input @kazurayam.
I am however upvoting for @katalon.team to contain the possibility to access current test case instance in the TestSuite dedicated scripting area also.
I believe this is the main reason why you should use dedicated test suite scripting for such events, to access the specific suite and test cases context.
The other test listeners are for a generic project approach.
Of course I may be biased and seeing only a small portion of the entire picture here.
Thank you,
Cornel
