Hello Everyone,
I hope you are having a good day. I would like to bring to your attention a critical bug I have discovered in Katalon.
The issue arises when running a test suite collection in parallel mode with at least two devices. An exception error “org.openqa.selenium.WebDriverException: An unknown server-side error occurred while processing the command. Original error: Could not proxy command to the remote server. Original error: socket hang up” is raised under these conditions.
I have created a simple project to ensure there are no other factors that could cause this issue.
Here is the code being used
testcase 1
import static com.kms.katalon.core.checkpoint.CheckpointFactory.findCheckpoint;
import static com.kms.katalon.core.testcase.TestCaseFactory.findTestCase;
import static com.kms.katalon.core.testdata.TestDataFactory.findTestData;
import static com.kms.katalon.core.testobject.ObjectRepository.findTestObject;
import static com.kms.katalon.core.testobject.ObjectRepository.findWindowsObject;
import com.kms.katalon.core.checkpoint.Checkpoint;
import com.kms.katalon.core.cucumber.keyword.CucumberBuiltinKeywords as CucumberKW;
import com.kms.katalon.core.mobile.keyword.MobileBuiltInKeywords as Mobile;
import com.kms.katalon.core.model.FailureHandling as FailureHandling;
import com.kms.katalon.core.testcase.TestCase;
import com.kms.katalon.core.testdata.TestData;
import com.kms.katalon.core.testng.keyword.TestNGBuiltinKeywords as TestNGKW;
import com.kms.katalon.core.testobject.TestObject;
import com.kms.katalon.core.webservice.keyword.WSBuiltInKeywords as WS;
import com.kms.katalon.core.webui.keyword.WebUiBuiltInKeywords as WebUI;
import com.kms.katalon.core.windows.keyword.WindowsBuiltinKeywords as Windows;
import internal.GlobalVariable as GlobalVariable;
import org.openqa.selenium.Keys as Keys;
Mobile.verifyEqual("1", "1");
testcase2
Mobile.verifyEqual("10", "20");
testcase 3
Test Suites:
testSuite1containstestCase1testSuite2containstestCase2testSuite3containstestCase3
Test Suite Collection:
- Contains test suites:
[testSuite1, testSuite2, testSuite3] - Execution Mode: Parallel
- Max concurrent: 2
Expected Result: The execution should run smoothly.
Actual Result: The execution starts, but some connected devices show an error message.
Important Notes:
- This test was conducted on three devices: [Note20, OnePlus Nord, Galaxy A51, Lenovo K15].
- Multiple USB debugging methods were used (two types of USBs, wireless debugging for 5G network).
- The issue does not occur when executing normally through an individual test suite or possibly in sequential mode in the test suite collection.
- I have tried to re-install the Android SDK from the katalon and tried to used different SDK, but same issue existed
Logs for test suite collection run
2024-06-13 07:37:30.517 INFO c.k.katalon.core.main.TestSuiteExecutor - START Test Suites/testSuite2
2024-06-13 07:37:30.644 INFO c.k.katalon.core.main.TestSuiteExecutor - hostName = user - DESKTOP-4OAJ0LS
2024-06-13 07:37:30.646 INFO c.k.katalon.core.main.TestSuiteExecutor - os = Windows 10 64bit
2024-06-13 07:37:30.648 INFO c.k.katalon.core.main.TestSuiteExecutor - hostAddress = 192.168.0.160
2024-06-13 07:37:30.650 INFO c.k.katalon.core.main.TestSuiteExecutor - katalonVersion = 9.0.0.212
Before Test Suite
2024-06-13 07:37:32.104 INFO c.k.k.c.a.driver.AppiumDriverManager - Detected NodeJS location: "C:\Program Files\nodejs\node.exe"
e[35m[Appium]e[39m Welcome to Appium v1.21.0
e[35m[Appium]e[39m Non-default server args:
e[35m[Appium]e[39m port: 51796
e[35m[Appium]e[39m loglevel: info
e[35m[Appium]e[39m tmpDir: C:\Users\user\AppData\Local\Temp\\Katalon\Appium\Temp1718289451644
e[35m[Appium]e[39m chromedriverPort: 51797
e[35m[Appium]e[39m Deprecated server args:
e[35m[Appium]e[39m e[31m--chromedriver-porte[39m => --default-capabilities
e[35m[Appium]e[39m Default capabilities, which will be added to each request unless overridden by desired capabilities:
e[35m[Appium]e[39m Appium REST http interface listener started on 0.0.0.0:51796
2024-06-13 07:37:35.246 INFO c.k.k.c.a.driver.AppiumDriverManager - Appium server started on port 51,796
e[35m[HTTP]e[39m e[37m-->e[39m e[37mGETe[39m e[37m/wd/hub/statuse[39m
e[35m[HTTP]e[39m e[90m{}e[39m
e[35m[HTTP]e[39m e[37m<-- GET /wd/hub/status e[39me[32m200e[39m e[90m16 ms - 68e[39m
e[35m[HTTP]e[39m e[90me[39m
e[35m[HTTP]e[39m e[37m-->e[39m e[37mPOSTe[39m e[37m/wd/hub/sessione[39m
e[35m[HTTP]e[39m e[90m{"desiredCapabilities":{"appActivity":".Settings","appPackage":"com.android.settings","newCommandTimeout":1800,"platformVersion":"12","automationName":"uiautomator2","autoGrantPermissions":true,"platformName":"Android","udid":"RZ8MC1EVY4X","deviceName":"samsung SM-A515F (Android 12)","platform":"ANDROID","systemPort":8271},"capabilities":{"firstMatch":[{"appium:appActivity":".Settings","appium:appPackage":"com.android.settings","appium:autoGrantPermissions":true,"appium:automationName":"uiautomator2","appium:deviceName":"samsung SM-A515F (Android 12)","appium:newCommandTimeout":1800,"platform":"ANDROID","platformName":"android","appium:platformVersion":"12","appium:systemPort":8271,"appium:udid":"RZ8MC1EVY4X"}]}}e[39m
e[35m[BaseDriver]e[39m The following capabilities are not standard capabilities and should have an extension prefix:
e[35m[BaseDriver]e[39m platform
e[35m[BaseDriver]e[39m chromedriverPort
e[35m[Appium]e[39m Appium v1.21.0 creating new AndroidUiautomator2Driver (v1.65.0) session
e[35m[BaseDriver]e[39m The following capabilities were provided, but are not recognized by Appium:
e[35m[BaseDriver]e[39m Session created with session id: 8d77e58c-e2e0-4ee6-baa4-01cf6d93d45d
e[35m[UiAutomator2]e[39m Starting 'com.android.settings' directly on the device
e[35m[ADB]e[39m Found 2 'build-tools' folders under 'C:\Users\user\AppData\Local\Android\Sdk' (newest first):
e[35m[ADB]e[39m C:/Users/user/AppData/Local/Android/Sdk/build-tools/34.0.0
e[35m[ADB]e[39m C:/Users/user/AppData/Local/Android/Sdk/build-tools/29.0.3
e[35m[ADB]e[39m Using 'adb.exe' from 'C:\Users\user\AppData\Local\Android\Sdk\platform-tools\adb.exe'
e[35m[AndroidDriver]e[39m Retrieving device list
e[35m[AndroidDriver]e[39m Using device: RZ8MC1EVY4X
e[35m[ADB]e[39m Getting device platform version
e[35m[UiAutomator2]e[39m Relaxing hidden api policy
e[35m[AndroidDriver]e[39m No app sent in, not parsing package/activity
e[35m[ADB]e[39m The application at 'C:\Users\USER\AppData\Roaming\npm\node_modules\appium\node_modules\io.appium.settings\apks\settings_apk-debug.apk' will not be cached, because the device under test has confirmed the support of streamed installs
e[35m[ADB]e[39m The installation of 'settings_apk-debug.apk' took 484ms
e[35m[ADB]e[39m Using 'apksigner.jar' from 'C:\Users\user\AppData\Local\Android\Sdk\build-tools\34.0.0\lib\apksigner.jar'
e[35m[ADB]e[39m 'C:\Users\USER\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-server\apks\appium-uiautomator2-server-v4.21.1.apk' is signed with the default certificate
e[35m[ADB]e[39m 'C:\Users\USER\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-server\apks\appium-uiautomator2-server-debug-androidTest.apk' is signed with the default certificate
e[35m[UiAutomator2]e[39m Server packages are going to be (re)installed
e[35m[ADB]e[39m The application at 'C:\Users\USER\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-server\apks\appium-uiautomator2-server-v4.21.1.apk' will not be cached, because the device under test has confirmed the support of streamed installs
e[35m[ADB]e[39m The installation of 'appium-uiautomator2-server-v4.21.1.apk' took 387ms
e[35m[ADB]e[39m The application at 'C:\Users\USER\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-server\apks\appium-uiautomator2-server-debug-androidTest.apk' will not be cached, because the device under test has confirmed the support of streamed installs
e[35m[ADB]e[39m The installation of 'appium-uiautomator2-server-debug-androidTest.apk' took 942ms
e[35m[ADB]e[39m Adding packages ["io.appium.settings","io.appium.uiautomator2.server","io.appium.uiautomator2.server.test"] to Doze whitelist
e[35m[UiAutomator2]e[39m Starting UIAutomator2 server 4.21.1
e[35m[UiAutomator2]e[39m Using UIAutomator2 server from 'C:\Users\USER\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-server\apks\appium-uiautomator2-server-v4.21.1.apk' and test from 'C:\Users\USER\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-server\apks\appium-uiautomator2-server-debug-androidTest.apk'
e[35m[UiAutomator2]e[39m Waiting up to 30000ms for UiAutomator2 to be online...
e[35m[WD Proxy]e[39m socket hang up
e[35m[UiAutomator2]e[39m The instrumentation process has been unexpectedly terminated. Retrying UiAutomator2 startup (#1 of 1)
e[35m[ADB]e[39m No 'uiautomator' process has been found
e[35m[WD Proxy]e[39m Determined the downstream protocol as 'W3C'
e[35m[AndroidDriver]e[39m Screen already unlocked, doing nothing
e[35m[UiAutomator2]e[39m Starting 'com.android.settings/.Settings and waiting for 'com.android.settings/.Settings'
e[35m[UiAutomator2]e[39m Did not get confirmation UiAutomator2 deleteSession worked; Error was: UnknownError: An unknown server-side error occurred while processing the command. Original error: Could not proxy command to the remote server. Original error: socket hang up
2024-06-13 07:37:57.945 INFO c.k.k.c.a.driver.AppiumDriverManager - deviceId = RZ8MC1EVY4X
2024-06-13 07:37:57.945 INFO c.k.k.c.a.driver.AppiumDriverManager - deviceName = samsung SM-A515F (Android 12)
2024-06-13 07:37:57.946 INFO c.k.k.c.a.driver.AppiumDriverManager - deviceModel = SM-A515F
2024-06-13 07:37:57.947 INFO c.k.k.c.a.driver.AppiumDriverManager - deviceManufacturer = samsung
2024-06-13 07:37:57.948 INFO c.k.k.c.a.driver.AppiumDriverManager - deviceOS = Android
2024-06-13 07:37:57.949 INFO c.k.k.c.a.driver.AppiumDriverManager - deviceOSVersion = 12
2024-06-13 07:37:57.989 ERROR c.k.k.core.keyword.internal.KeywordMain - ❌ Unable to start app with application ID: 'com.urpay.consumer.sit' (Root cause: org.openqa.selenium.SessionNotCreatedException: Unable to create a new remote session. Please check the server log for more details. Original error: An unknown server-side error occurred while processing the command. Original error: Could not proxy command to the remote server. Original error: socket hang up
Build info: version: '3.141.59', revision: 'e82be7d358', time: '2018-11-14T08:25:53'
System info: host: 'DESKTOP-4OAJ0LS', ip: '192.168.0.160', os.name: 'Windows 10', os.arch: 'amd64', os.version: '10.0', java.version: '17.0.7'
Driver info: driver.version: MobileDriverFactory$startMobileDriver
remote stacktrace: UnknownError: An unknown server-side error occurred while processing the command. Original error: Could not proxy command to the remote server. Original error: socket hang up
at UIA2Proxy.command (C:\Users\USER\AppData\Roaming\npm\node_modules\appium\node_modules\appium-base-driver\lib\jsonwp-proxy\proxy.js:274:13)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at AndroidUiautomator2Driver.commands.getDevicePixelRatio (C:\Users\USER\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-driver\lib\commands\viewport.js:14:10)
at AndroidUiautomator2Driver.fillDeviceDetails (C:\Users\USER\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-driver\lib\driver.js:238:28)
at AndroidUiautomator2Driver.createSession (C:\Users\USER\AppData\Roaming\npm\node_modules\appium\node_modules\appium-uiautomator2-driver\lib\driver.js:224:7)
at AppiumDriver.createSession (C:\Users\USER\AppData\Roaming\npm\node_modules\appium\lib\appium.js:387:35)
at io.appium.java_client.remote.AppiumCommandExecutor$1.createSession(AppiumCommandExecutor.java:208)
at io.appium.java_client.remote.AppiumCommandExecutor.createSession(AppiumCommandExecutor.java:217)
at io.appium.java_client.remote.AppiumCommandExecutor.execute(AppiumCommandExecutor.java:239)
at org.openqa.selenium.remote.RemoteWebDriver.execute(RemoteWebDriver.java:552)
at io.appium.java_client.DefaultGenericMobileDriver.execute(DefaultGenericMobileDriver.java:42)
at io.appium.java_client.AppiumDriver.execute(AppiumDriver.java:1)
at io.appium.java_client.android.AndroidDriver.execute(AndroidDriver.java:1)
at com.kms.katalon.core.appium.driver.SwipeableAndroidDriver.execute(SwipeableAndroidDriver.java:1)
at org.openqa.selenium.remote.RemoteWebDriver.startSession(RemoteWebDriver.java:213)
at org.openqa.selenium.remote.RemoteWebDriver.<init>(RemoteWebDriver.java:131)
at io.appium.java_client.DefaultGenericMobileDriver.<init>(DefaultGenericMobileDriver.java:38)
at io.appium.java_client.AppiumDriver.<init>(AppiumDriver.java:84)
at io.appium.java_client.android.AndroidDriver.<init>(AndroidDriver.java:85)
at com.kms.katalon.core.appium.driver.SwipeableAndroidDriver.<init>(SwipeableAndroidDriver.java:24)
at com.kms.katalon.core.appium.driver.AppiumDriverManager.createMobileDriver(AppiumDriverManager.java:510)
at com.kms.katalon.core.appium.driver.AppiumDriverManager.createMobileDriver(AppiumDriverManager.java:492)
at com.kms.katalon.core.mobile.keyword.internal.MobileDriverFactory.startMobileDriver(MobileDriverFactory.java:446)
at com.kms.katalon.core.mobile.keyword.internal.MobileDriverFactory$startMobileDriver.call(Unknown Source)
at com.kms.katalon.core.mobile.keyword.builtin.StartExistingApplicationKeyword$_startApplication_closure1.doCall(StartExistingApplicationKeyword.groovy:49)
at com.kms.katalon.core.mobile.keyword.builtin.StartExistingApplicationKeyword$_startApplication_closure1.doCall(StartExistingApplicationKeyword.groovy)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at com.kms.katalon.core.mobile.keyword.internal.MobileKeywordMain.runKeyword(MobileKeywordMain.groovy:21)
at com.kms.katalon.core.mobile.keyword.internal.MobileKeywordMain$runKeyword.call(Unknown Source)
at com.kms.katalon.core.mobile.keyword.builtin.StartExistingApplicationKeyword.startApplication(StartExistingApplicationKeyword.groovy:52)
at com.kms.katalon.core.mobile.keyword.builtin.StartExistingApplicationKeyword.execute(StartExistingApplicationKeyword.groovy:37)
at com.kms.katalon.core.keyword.internal.KeywordExecutor.executeKeywordForPlatform(KeywordExecutor.groovy:74)
at com.kms.katalon.core.mobile.keyword.MobileBuiltInKeywords.startExistingApplication(MobileBuiltInKeywords.groovy:92)
at USpaceListener.sampleBeforeTestSuite(NewTestListener.groovy:64)
at com.kms.katalon.core.context.internal.TestHooker.invokeMethod(TestHooker.java:111)
at com.kms.katalon.core.context.internal.TestHooker.lambda$3(TestHooker.java:95)
at com.kms.katalon.core.context.internal.TestHooker.invokeContextMethods(TestHooker.java:94)
at com.kms.katalon.core.context.internal.TestListenerCollector.lambda$3(TestListenerCollector.java:88)
at com.kms.katalon.core.context.internal.TestListenerCollector.handleListenerEvent(TestListenerCollector.java:85)
at com.kms.katalon.core.context.internal.ExecutionEventManager.publicEvent(ExecutionEventManager.java:36)
at com.kms.katalon.core.main.TestSuiteExecutor.execute(TestSuiteExecutor.java:104)
at com.kms.katalon.core.main.TestCaseMain.startTestSuite(TestCaseMain.java:187)
at TempTestSuite1718289432868.run(TempTestSuite1718289432868.groovy:36)
Caused by: java.lang.reflect.InvocationTargetException
at io.appium.java_client.remote.AppiumCommandExecutor$1.createSession(AppiumCommandExecutor.java:186)
... 44 more
Caused by: org.openqa.selenium.WebDriverException: An unknown server-side error occurred while processing the command. Original error: Could not proxy command to the remote server. Original error: socket hang up
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at org.openqa.selenium.remote.W3CHandshakeResponse.lambda$errorHandler$0(W3CHandshakeResponse.java:62)
at org.openqa.selenium.remote.HandshakeResponse.lambda$getResponseFunction$0(HandshakeResponse.java:30)
at org.openqa.selenium.remote.ProtocolHandshake.lambda$createSession$0(ProtocolHandshake.java:126)
at org.openqa.selenium.remote.ProtocolHandshake.createSession(ProtocolHandshake.java:128)
... 48 more
2024-06-13 07:37:58.002 ERROR c.k.k.core.context.internal.TestHooker - ❌ com.kms.katalon.core.exception.StepFailedException: Unable to start app with application ID: 'com.urpay.consumer.sit' (Root cause: org.openqa.selenium.SessionNotCreatedException: Unable to create a new remote session. Please check the server log for more details. Original error: An unknown server-side error occurred while processing the command. Original error: Could not proxy command to the remote server. Original error: socket hang up
... 44 more
... 48 more
at com.kms.katalon.core.keyword.internal.KeywordMain.stepFailed(KeywordMain.groovy:51)
at com.kms.katalon.core.mobile.keyword.internal.MobileKeywordMain.stepFailed(MobileKeywordMain.groovy:40)
at com.kms.katalon.core.mobile.keyword.internal.MobileKeywordMain.runKeyword(MobileKeywordMain.groovy:23)
Caused by: org.openqa.selenium.SessionNotCreatedException: Unable to create a new remote session. Please check the server log for more details. Original error: An unknown server-side error occurred while processing the command. Original error: Could not proxy command to the remote server. Original error: socket hang up
... 21 more
... 44 more
... 48 more
2024-06-13 07:37:58.197 INFO c.k.katalon.core.main.TestCaseExecutor - --------------------
2024-06-13 07:37:58.198 INFO c.k.katalon.core.main.TestCaseExecutor - START Test Cases/test2
Test Cases/test2
e[35m[UiAutomator2]e[39m Restoring hidden api policy to the device default configuration
e[35m[HTTP]e[39m e[37m<-- POST /wd/hub/session e[39me[31m500e[39m e[90m21008 ms - 1310e[39m
2024-06-13 07:37:58.456 DEBUG testcase.test2 - 1: verifyEqual("10", "20")
2024-06-13 07:37:58.517 ERROR c.k.k.core.keyword.internal.KeywordMain - ❌ Unable to verify equal between actual object '10' and expected object '20' (Root cause: com.kms.katalon.core.exception.StepFailedException: Actual object '10' and expected object '20' are not equal
at com.kms.katalon.core.keyword.builtin.VerifyEqualKeyword$_verifyEqual_closure1.doCall(VerifyEqualKeyword.groovy:58)
at com.kms.katalon.core.keyword.builtin.VerifyEqualKeyword$_verifyEqual_closure1.call(VerifyEqualKeyword.groovy)
at com.kms.katalon.core.keyword.internal.KeywordMain.runKeyword(KeywordMain.groovy:75)
at com.kms.katalon.core.keyword.builtin.VerifyEqualKeyword.verifyEqual(VerifyEqualKeyword.groovy:63)
at com.kms.katalon.core.keyword.builtin.VerifyEqualKeyword.execute(VerifyEqualKeyword.groovy:44)
at com.kms.katalon.core.keyword.BuiltinKeywords.verifyEqual(BuiltinKeywords.groovy:146)
at test2.run(test2:22)
at com.kms.katalon.core.main.TestCaseExecutor.runScript(TestCaseExecutor.java:448)
at com.kms.katalon.core.main.TestCaseExecutor.doExecute(TestCaseExecutor.java:439)
at com.kms.katalon.core.main.TestCaseExecutor.processExecutionPhase(TestCaseExecutor.java:418)
at com.kms.katalon.core.main.TestCaseExecutor.accessMainPhase(TestCaseExecutor.java:410)
at com.kms.katalon.core.main.TestCaseExecutor.execute(TestCaseExecutor.java:285)
at com.kms.katalon.core.common.CommonExecutor.accessTestCaseMainPhase(CommonExecutor.java:65)
at com.kms.katalon.core.main.TestSuiteExecutor.accessTestSuiteMainPhase(TestSuiteExecutor.java:148)
at com.kms.katalon.core.main.TestSuiteExecutor.execute(TestSuiteExecutor.java:106)
2024-06-13 07:37:58.524 ERROR c.k.katalon.core.main.TestCaseExecutor - ❌ Test Cases/test2 FAILED.
Test Cases/test2
FAILED
2024-06-13 07:37:58.541 INFO c.k.katalon.core.main.TestCaseExecutor - END Test Cases/test2
2024-06-13 07:37:58.992 INFO com.kms.katalon.core.util.KeywordUtil - Start generating HTML report folder at: C:\Users\user\Katalon Studio\MobileProject\Reports\20240613_073711\testSuite2\20240613_073712...
2024-06-13 07:37:59.051 INFO com.kms.katalon.core.util.KeywordUtil - HTML report generated
2024-06-13 07:37:59.052 INFO com.kms.katalon.core.util.KeywordUtil - Start generating CSV report folder at: C:\Users\user\Katalon Studio\MobileProject\Reports\20240613_073711\testSuite2\20240613_073712...
2024-06-13 07:37:59.074 INFO com.kms.katalon.core.util.KeywordUtil - CSV report generated
2024-06-13 07:37:59.574 INFO c.k.katalon.core.main.TestSuiteExecutor - --------------------
2024-06-13 07:37:59.574 INFO c.k.katalon.core.main.TestSuiteExecutor - END Test Suites/testSuite2
2024-06-13 07:37:59.574 INFO c.k.katalon.core.main.TestSuiteExecutor - ====================
Katalon version: 9.0.0
OS: windows 10
Mobile versions: Android 13 & 12
Severity: critical
priority: high
