I have used this Setting till 5.5 version of KatalonVersion, but this looks disabled from 5.6.3
I’ve seen this is many versions of Katalon. It’s usually the case that Katalon thinks a test (or suite) is running.
If you kill all drivers (see code below) does it recover?
Run these from the shell (better, create a batch file/shell script)
taskkill /f /im geckodriver.exe
taskkill /f /im chromedriver.exe
taskkill /f /im IEDriverServer.exe
