Q: How do I execute my tests (or my QA pipelines) with only Katalon and not in Integrated platforms that can be costly (they can sometimes be more expensive than Katalon).
I am referring to Katalon’s partners like Kobiton or BrowserStack. So, why does Katalon not have a multi-device platform or a configurable simulator where we can execute our Mobile Testing Pipelines?
A: We have our in-house product Test Cloud which you can use for Mulit-device and Cross-devices testing.
Q: How do I use other mobile keywords for Mobile automation testing?
A: You can use other mobile keywords also while recording mode or in the manual mode and you can add objects in the object repository manually.
Q: Can particular tests be tagged and have the capability to run like for example, those smoke test runs?
A: You can use Test Suite for better test management, we can use Test Suite Collections where we can do different integration with different runs.
Q: if I integrated the Katalon project with Github in Katalon’s Free plan, is is possible to use it after 6 months by cloning that Git project?
A: Yes, you can reuse the same Repository.
