Hi.
I have some test cases which are dependent on each other so Test Suite should not continue for other test cases. How can I adjust my test suite for this purpose ?
Briefly, if one test case fails, then test suite should be ended.
Hi.
Hello
Take a look at this topic:
http://forum.katalon.com/discussion/1988/can-i-create-a-dependency-between-testcases
I believe you could use the FailureHandling which is described here:
https://docs.katalon.com/display/KD/Failure+handling
You can also use KeywordUtil.markFailed/markFailedAndStop to mark the test as failed and stop the execution.
https://api-docs.katalon.com/com/kms/katalon/core/util/KeywordUtil.html
Mate Mrse said:
Hello
Take a look at this topic:http://forum.katalon.com/discussion/1988/can-i-create-a-dependency-between-testcases
Your link doesn’t work !!
The same discussion here:
I have got a practical solution to this problem:
