Operating System
- For example: Mac OS Catalina
Katalon Studio Version
7.3.0
Katalon Studio logs
java.util.concurrent.ExecutionException: org.openqa.selenium.SessionNotCreatedException: Unable to create a new remote session. Please check the server log for more details. Original error: An unknown server-side error occurred while processing the command. Original error: Unable to launch WebDriverAgent because of xcodebuild failure: xcodebuild failed with code 65
xcodebuild error message:
2020-04-15 15:24:28.908 xcodebuild[2744:82499] Error writing xctestrun file: Error Domain=NSCocoaErrorDomain Code=4 âThe folder âWebDriverAgentRunner_iphoneos13.4-arm64e.xctestrunâ doesnât exist.â UserInfo={NSFilePath=/Users/sabyasachi/Library/Developer/Xcode/DerivedData/WebDriverAgent-ciegwgvxzxdrqthilmrmczmqvrgu/Build/Products/WebDriverAgentRunner_iphoneos13.4-arm64e.xctestrun, NSUserStringVariant=Folder, NSUnderlyingError=0x7fc1053557b0 {Error Domain=NSPOSIXErrorDomain Code=2 âNo such file or directoryâ}}
** TEST BUILD FAILED **
2020-04-15 15:24:28.920 xcodebuild[2744:82490] IDETestOperationsObserverDebug: Writing diagnostic log for test session to:
/Users/sabyasachi/Library/Developer/Xcode/DerivedData/WebDriverAgent-ciegwgvxzxdrqthilmrmczmqvrgu/Logs/Test/Test-WebDriverAgentRunner-2020.04.15_15-24-28-+0530.xcresult/Staging/2_Test/Diagnostics/WebDriverAgentRunner-C0523901-BBC4-4973-8214-976F78B8E902/WebDriverAgentRunner-7373EA85-2E72-4946-941C-15EDFCF2C050/Session-WebDriverAgentRunner-2020-04-15_152428-lw99c6.log
2020-04-15 15:24:28.920 xcodebuild[2744:82438] [MT] IDETestOperationsObserverDebug: (398049A1-AC3E-4B3E-BAE9-96F7B7486C64) Beginning test session WebDriverAgentRunner-398049A1-AC3E-4B3E-BAE9-96F7B7486C64 at 2020-04-15 15:24:28.920 with Xcode 11E146 on target
<DVTiOSDevice (0x7fc10c6e82c0), iPhone, iPhone, 13.1.3 (17A878), 00008030-0004654C1182802E> {
deviceSerialNumber: FK2ZK9XYN70R
identifier: 00008030-0004654C1182802E
deviceClass: iPhone
deviceName: iPhone
deviceIdentifier: 00008030-0004654C1182802E
productVersion: 13.1.3
buildVersion: 17A878
deviceSoftwareVersion: 13.1.3 (17A878)
deviceArchitecture: arm64e
deviceTotalCapacity: 57999921152
deviceAvailableCapacity: 47809523712
deviceIsTransient: NO
ignored: NO
deviceIsBusy: NO
deviceIsPaired: YES
deviceIsActivated: YES
deviceActivationState: Activated
isPasscodeLocked: NO
deviceType: <DVTDeviceType:0x7fc10c2d79e0 Xcode.DeviceType.iPhone>
supportedDeviceFamilies: (
1
applications: (null)
provisioningProfiles: (null)
hasInternalSupport: NO
hasWritableSystem: NO
isSupportedOS: YES
bootArgs: (null)
nextBootArgs: (null)
connected: YES
isWirelessEnabled: NO
connectionType: direct
hostname: (null)
bonjourServiceName: f8:ff:c2:ed:df:03@fe80::faff:c2ff:feed:df03._apple-mobdev2._tcp.local.
activeProxiedDevice: (null)
} (13.1.3 (17A878))
2020-04-15 15:24:29.037 xcodebuild[2744:82438] [MT] IDETestOperationsObserverDebug: (398049A1-AC3E-4B3E-BAE9-96F7B7486C64) Finished requesting crash reports. Continuing with testing.
*** If you believe this error represents a bug, please attach the result bundle at /Users/sabyasachi/Library/Developer/Xcode/DerivedData/WebDriverAgent-ciegwgvxzxdrqthilmrmczmqvrgu/Logs/Test/Test-WebDriverAgentRunner-2020.04.15_15-24-28-+0530.xcresult
2020-04-15 15:24:29.047 xcodebuild[2744:82438] [MT] IDETestOperationsObserverDebug: 0.131 elapsed â Testing started completed.
2020-04-15 15:24:29.047 xcodebuild[2744:82438] [MT] IDETestOperationsObserverDebug: 0.000 sec, +0.000 sec â start
2020-04-15 15:24:29.047 xcodebuild[2744:82438] [MT] IDETestOperationsObserverDebug: 0.131 sec, +0.131 sec â end
2020-04-15 15:24:29.047 xcodebuild[2744:82438] Error Domain=NSCocoaErrorDomain Code=260 âThe file âWebDriverAgentRunner-Runner.appâ couldnât be opened because there is no such file.â UserInfo={NSFilePath=/Users/sabyasachi/Library/Developer/Xcode/DerivedData/WebDriverAgent-ciegwgvxzxdrqthilmrmczmqvrgu/Build/Products/Debug-iphoneos/WebDriverAgentRunner-Runner.app, NSUnderlyingError=0x7fc10c7d1b70 {Error Domain=NSPOSIXErrorDomain Code=2 âNo such file or directoryâ}}
Test session results, code coverage, and logs:
Testing failed:
Signing for âWebDriverAgentRunnerâ requires a development team. Select a development team in the Signing & Capabilities editor.
WebDriverAgentRunner:
WebDriverAgentRunner-Runner.app encountered an error (Failed to install or launch the test runner. (Underlying error: The file âWebDriverAgentRunner-Runner.appâ couldnât be opened because there is no such file. The file doesnât exist. (Underlying error: The operation couldnât be completed. No such file or directory)))
** TEST EXECUTE FAILED **
Testing started on âiPhoneâ. Make sure you follow the tutorial at appium-xcuitest-driver/real-device-config.md at master ¡ appium/appium-xcuitest-driver ¡ GitHub. Try to remove the WebDriverAgentRunner application from the device if it is installed and reboot the device.
Build info: version: âunknownâ, revision: âunknownâ, time: âunknownâ
System info: host: âBLR19C02ZJ36XLVCG.connectifyâ, ip: âfe80:0:0:0:c40:74c9:8144:1d81%en0â, os.name: âMac OS Xâ, os.arch: âx86_64â, os.version: â10.15.3â, java.version: â1.8.0_181â
Driver info: driver.version: IOSDriver
remote stacktrace: UnknownError: An unknown server-side error occurred while processing the command. Original error: Unable to launch WebDriverAgent because of xcodebuild failure: xcodebuild failed with code 65
deviceClass: iPhone
deviceName: iPhone
ignored: NO
deviceIsBusy: NO
deviceIsPaired: YES
1
isSupportedOS: YES
bootArgs: (null)
connected: YES
hostname: (null)
} (13.1.3 (17A878))
Testing failed:
at getResponseForW3CError (/usr/local/lib/node_modules/appium/node_modules/appium-base-driver/lib/protocol/errors.js:804:9)
at asyncHandler (/usr/local/lib/node_modules/appium/node_modules/appium-base-driver/lib/protocol/protocol.js:392:37)
at runNextTicks (internal/process/task_queues.js:58:5)
at processImmediate (internal/timers.js:412:9)
at com.kms.katalon.composer.components.impl.dialogs.ProgressMonitorDialogWithThread.runAndWait(ProgressMonitorDialogWithThread.java:49)
at com.kms.katalon.composer.mobile.objectspy.components.MobileLocalAppComposite$12.run(MobileLocalAppComposite.java:474)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Caused by: org.openqa.selenium.SessionNotCreatedException: Unable to create a new remote session. Please check the server log for more details. Original error: An unknown server-side error occurred while processing the command. Original error: Unable to launch WebDriverAgent because of xcodebuild failure: xcodebuild failed with code 65
deviceClass: iPhone
deviceName: iPhone
ignored: NO
deviceIsBusy: NO
deviceIsPaired: YES
1
isSupportedOS: YES
bootArgs: (null)
connected: YES
hostname: (null)
} (13.1.3 (17A878))
Testing failed:
deviceClass: iPhone
deviceName: iPhone
ignored: NO
deviceIsBusy: NO
deviceIsPaired: YES
1
isSupportedOS: YES
bootArgs: (null)
connected: YES
hostname: (null)
} (13.1.3 (17A878))
Testing failed:
at io.appium.java_client.remote.AppiumCommandExecutor$1.createSession(AppiumCommandExecutor.java:208)
at io.appium.java_client.remote.AppiumCommandExecutor.createSession(AppiumCommandExecutor.java:217)
at io.appium.java_client.remote.AppiumCommandExecutor.execute(AppiumCommandExecutor.java:239)
at org.openqa.selenium.remote.RemoteWebDriver.execute(RemoteWebDriver.java:552)
at io.appium.java_client.DefaultGenericMobileDriver.execute(DefaultGenericMobileDriver.java:42)
at io.appium.java_client.AppiumDriver.execute(AppiumDriver.java:1)
at io.appium.java_client.ios.IOSDriver.execute(IOSDriver.java:1)
at org.openqa.selenium.remote.RemoteWebDriver.startSession(RemoteWebDriver.java:213)
at org.openqa.selenium.remote.RemoteWebDriver.(RemoteWebDriver.java:131)
at io.appium.java_client.DefaultGenericMobileDriver.(DefaultGenericMobileDriver.java:38)
at io.appium.java_client.AppiumDriver.(AppiumDriver.java:84)
at io.appium.java_client.ios.IOSDriver.(IOSDriver.java:85)
at com.kms.katalon.core.appium.driver.AppiumDriverManager.createMobileDriver(AppiumDriverManager.java:495)
at com.kms.katalon.core.appium.driver.AppiumDriverManager.createMobileDriver(AppiumDriverManager.java:479)
at com.kms.katalon.core.mobile.keyword.internal.MobileDriverFactory.startLocalMobileDriver(MobileDriverFactory.java:458)
at com.kms.katalon.composer.mobile.objectspy.dialog.MobileInspectorController.startMobileApp(MobileInspectorController.java:191)
at com.kms.katalon.composer.mobile.objectspy.components.MobileLocalAppComposite$12$1.call(MobileLocalAppComposite.java:479)
at com.kms.katalon.composer.components.impl.dialogs.ProgressMonitorDialogWithThread.startThreadAndWait(ProgressMonitorDialogWithThread.java:36)
at com.kms.katalon.composer.components.impl.dialogs.ProgressMonitorDialogWithThread.runAndWait(ProgressMonitorDialogWithThread.java:48)
⌠2 more
Caused by: java.lang.reflect.InvocationTargetException
at io.appium.java_client.remote.AppiumCommandExecutor$1.createSession(AppiumCommandExecutor.java:186)
⌠20 more
Caused by: org.openqa.selenium.WebDriverException: An unknown server-side error occurred while processing the command. Original error: Unable to launch WebDriverAgent because of xcodebuild failure: xcodebuild failed with code 65
Environment (for Mobile testing)
Appium version: 1.17.0
Mobile platform/version under test: iOS 11
Real device or emulator/simulator: iPhone 11pro real or iPhone 8 simulator
Xcode version (for iOS): Xcode 11.4
Steps to reproduce
Create test case and start recording
