I have published a GitHub Repository:
I have developed a utility class com.kazurayam.ks.ContextTrace for Katalon Studio project, which enables a Test Case script to get its own “Test Case ID” and other useful identifications programatically at runtime.
Prerequisites
You need Katalon Studio of version 10.0.0 or newer as this library was developed on v10 which restored the “Custom Keyword” feature for the Free version.
No Katalon Enterprise license is required to use this library
Where to download the jar
You can download the ks-context-trace-*.jar file from the Releases page of the GitHub project at
You need to manually put the jar into the Drivers folder of your Katalon project and reopen your project. See the doc “Library management in Katalon Studio”
Usage
create a TestListener
You need to create a TestListener in your Katalon project. The file could be named any. E.g, Test Listeners/SetupContextTrace.groovy.
You can copy and paste the following code (no change will be required):
import com.kazurayam.ks.ContextTrace
import com.kms.katalon.core.annotation.BeforeTestCase
import com.kms.katalon.core.annotation.BeforeTestSuite
import com.kms.katalon.core.context.TestCaseContext
import com.kms.katalon.core.context.TestSuiteContext
class SetupContextTrace {
@BeforeTestSuite
def beforeTestSuite(TestSuiteContext context) {
ContextTrace.setTestSuiteContext(context)
@BeforeTestCase
def beforeTestCase(TestCaseContext context) {
ContextTrace.setTestCaseContext(context)
This TestListener is essential for the com.kazurayam.ks.ContextTrace class to work properly.
Katalon Studio fires the beforeTestCase(TestCaseContext) and beforeTestSuite(TestSuiteContext) methods in the TestListener, which pass the context objects to the ContextTrace object. The ContextTrace object will memorize the context objects so that user’s TestCase scripts can referer to later when necessary.
write a Test Case that uses ContextTrace
Now you can use the ContextTrace anywhere in your Test Case scripts. For example, see
Test Cases/main/demo in the app project:
import static com.kms.katalon.core.testcase.TestCaseFactory.findTestCase
import com.kms.katalon.core.webui.keyword.WebUiBuiltInKeywords as WebUI
* main/demo
println "ContextTrace.getTestSuiteId(): " + ContextTrace.getTestSuiteId()
println "ContextTrace.escapedTestSuiteId(): " + ContextTrace.escapedTestSuiteId()
println "ContextTrace.getCurrentTestCaseId(): " + ContextTrace.getCurrentTestCaseId()
println "ContextTrace.getEscapedCurrentTestCaseId(): " + ContextTrace.getEscapedCurrentTestCaseId()
println "ContextTrace.getTestCaseIdStack(): " + ContextTrace.getTestCaseIdStack()
println "ContextTrace.escapedTestCaseIdChain(): " + ContextTrace.escapedTestCaseIdChain()
WebUI.callTestCase(findTestCase("main/demo_sub"), [:])
The Test Cases/main/demo calls Test Cases/main/demo_sub, which looks like this:
* main/demo_sub
ContextTrace.status()
When you run the Test Cases/main/demo, you will see the following messages in the Console tab of Katalon Studio:
- The statement
ContextTrace.getTestCaseIdStack()returned an instace ofjava.util.Stack, which was stringified into
[Test Cases/main/demo, Test Cases/main/demo_sub]
. This reveals that Katalon Studio launched Test Cases/main/demo, which then called the Test Cases/main/demo_sub via WebUI.callTestCase(...) keword.
- The statement
ContextTrace.escapedTestCaseIdChain()returned a string
main-demo,main-demo_sub
. This string was derived from the Stack instance that is returned by ContextTrace.getTestCaseIdStack().
- Please note that the returned value
main-demo,main-demo_subwas derived from the Test Case ID strings while slightly translated.
The leading prefix
Test Cases/was chomped off -
Forward slash character / was translated into a hypen -
Whitespace character was translated into a under bar _
A series of Test Cases chained by the
callTestCase()keyword is converted into a flat string delimited by comma ,
The string returned by
ContextTrace.escapedTestCaseIdChain()is shorter and more compact than the original TestCaseIds. -
ContextTrace.escapedTestCaseIdChain()is suitable for a file name, as it contains no special characters (<>:"/\|?*) which are prohibited as a part of file name in Windows. -
ContextTrace.getTestSuiteId()returns the Test Suite ID in which the current testcase belongs if the testcase was invoked by a wrapper Test Suite. If the testcase was executed directly without wrapping Test Suite, thenContextTrace.getTestSuiteId()will return null,ContextTrace.escapedTestSuiteId()will return an empty string “”.
API documentation
The API document of com.kazurayam.ks.ContextTrace is found here
What is the ContextTrace class useful for?
For example, when a test case in Katalon Studio takes a screenshot of browser, it is a good practice to save the PNG into a file named with the string returned by ContextTrace.escapedTestCaseIdChain(). The following document describes this idea with sample code:
Many other usecases you would be able to find. You can insert a string of escapedTestCaseIdChain into your RDB tables or No-SQL databases to record the test’s activities, that would make the records self-describing well.
History
This project succeeds my old project TestCaseStack. I have encapsulated my hack into a jar and published it.
