Hi Folks
I’m new in Katalon and wanted to know how to email the test report. I have tried sending email through Katalon but send test email option is showing grayed out and other options are not working
Hi @chickoontlk
Have you read the following documentation showing how to configure the Email settings:
Yes i’m using my outlook office mail and servers and while configuring it shows "Unable to send email to following server… ". I have tried all the basic possible solutions but they did not worked
Hi It start working and i’m able to generate test email as well as able to email test suit report to my organization email
Email Setting Required are for organization outlook:
Host name:Organization email server information
Port name: 25/587
Username:Organization username which you use for login in outlook
Password:Password for your username
Protocol:None
