Jenkin build shows test suite not found though test suite exist. I tried to run command without jenkins, got the same error.
Building in workspace /var/lib/jenkins/workspace/katalon[WS-CLEANUP] Deleting project workspace...[WS-CLEANUP] DoneCloning the remote Git repositoryCloning repository https://gitlab.com/OKRs/OKRs.git > git init /var/lib/jenkins/workspace/katalon # timeout=10Fetching upstream changes from https://gitlab.com/OKRs/OKRs.git > git --version # timeout=10using GIT_ASKPASS to set credentials > git fetch --tags --progress https://gitlab.com/OKRs/OKRs.git +refs/heads/*:refs/remotes/origin/* > git config remote.origin.url https://gitlab.com/OKRs/OKRs.git # timeout=10 > git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10 > git config remote.origin.url https://gitlab.com/OKRs/OKRs.git # timeout=10Fetching upstream changes from https://gitlab.com/OKRs/OKRs.gitusing GIT_ASKPASS to set credentials > git fetch --tags --progress https://gitlab.com/OKRs/OKRs.git +refs/heads/*:refs/remotes/origin/* > git rev-parse refs/remotes/origin/develop^{commit} # timeout=10 > git rev-parse refs/remotes/origin/origin/develop^{commit} # timeout=10Checking out Revision 9541006807174bfedcc1268beb7e98b7c43f7953 (refs/remotes/origin/develop)Commit message: "Update dispatch.yml" > git config core.sparsecheckout # timeout=10 > git checkout -f 9541006807174bfedcc1268beb7e98b7c43f7953 > git rev-list 9541006807174bfedcc1268beb7e98b7c43f7953 # timeout=10[katalon] $ /bin/sh -xe /tmp/jenkins6613783798045246595.sh+ cd /opt/katalon-5.3+ ./katalon -runMode=console -projectPath=/var/lib/jenkins/workspace/katalon/OKRS_Automation/OKRS_Project_Release1.prj -reportFolder=/var/lib/jenkins/workspace/katalon/OKRS_Automation/Reports/OKRTestSuite -reportFileName=report -retry=0 -testSuitePath=/var/lib/jenkins/workspace/katalon/OKRS_Automation/Test Suites/OKRTestSuite.ts -browserType=Chrome -data=/tmpStarting Groovy-Eclipse compiler resolver. Specified compiler level: unspecified131 2.4.7.xx-201611170128-e46 = ACTIVEcom.kms.katalon.execution.exception.ExecutionException: com.kms.katalon.execution.exception.InvalidConsoleArgumentException: Test suite '/var/lib/jenkins/workspace/katalon/OKRS_Automation/Test Suites/OKRTestSuite.ts' not found. at com.kms.katalon.execution.console.entity.TestSuiteLauncherOptionParser.getConsoleLauncher(TestSuiteLauncherOptionParser.java:73) at com.kms.katalon.execution.console.ConsoleExecutor.execute(ConsoleExecutor.java:67) at com.kms.katalon.execution.console.ConsoleMain.launch(ConsoleMain.java:81) at com.kms.katalon.console.application.Application.runConsole(Application.java:62) at com.kms.katalon.core.application.Application.runConsole(Application.java:72) at com.kms.katalon.core.application.Application.start(Application.java:56) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610) at org.eclipse.equinox.launcher.Main.run(Main.java:1519) at org.eclipse.equinox.launcher.Main.main(Main.java:1492)Caused by: com.kms.katalon.execution.exception.InvalidConsoleArgumentException: Test suite '/var/lib/jenkins/workspace/katalon/OKRS_Automation/Test Suites/OKRTestSuite.ts' not found. at com.kms.katalon.execution.console.entity.TestSuiteLauncherOptionParser.throwInvalidTestSuiteIdException(TestSuiteLauncherOptionParser.java:106) at com.kms.katalon.execution.console.entity.TestSuiteLauncherOptionParser.getTestSuite(TestSuiteLauncherOptionParser.java:101) at com.kms.katalon.execution.console.entity.TestSuiteLauncherOptionParser.getConsoleLauncher(TestSuiteLauncherOptionParser.java:64) ... 18 moreBuild step 'Execute shell' marked build as failureRecording test resultsERROR: Step 'Publish JUnit test result report' failed: No test report files were found. Configuration error?Finished: FAILURE
