I needed to find a way how to get the path of Katalon Studio installation folder programmatically.
I wrote a “Test Case/getInstallationFolder”:
// getInstallationFolder
import java.nio.file.Path;
import java.nio.file.Paths;
import java.security.CodeSource;
import com.kms.katalon.core.configuration.RunConfiguration
public Path getCodeSourcePathOf(Class<?> clazz) {
CodeSource codeSource = clazz.getProtectionDomain().getCodeSource();
URL url = codeSource.getLocation();
try {
return Paths.get(url.toURI());
} catch (URISyntaxException e) {
throw new RuntimeException(e);
Path jarPath = getCodeSourcePathOf(RunConfiguration.class)
println jarPath.toString()
Path pluginsPath = jarPath.getParent()
Path eclipsePath = pluginsPath.getParent()
Path contentsPath = eclipsePath.getParent()
Path installationFolderPath = contentsPath.getParent()
println installationFolderPath // on Mac, "/Applications/Katalon Studio.app"
I ran this, got the following output in the console:
2024-06-01 10:43:47.902 INFO c.k.katalon.core.main.TestCaseExecutor - --------------------
2024-06-01 10:43:47.906 INFO c.k.katalon.core.main.TestCaseExecutor - START Test Cases/getInstallationFolder
/Applications/Katalon Studio.app/Contents/Eclipse/plugins/com.kms.katalon.core_1.0.0.202310232352.jar
2024-06-01 10:43:48.943 INFO c.k.katalon.core.main.TestCaseExecutor - END Test Cases/getInstallationFolder
On Windows, the folder path will be something different. But no need to change the code. It will run on Linux as well.
