In previous iterations you used to be able to change this setting within the Test Cases tab in Preferences. This tab no longer exists
I don’t have 7.6.6 yet, did you try typing something into the search box?
Agh, just found it there, seems a lot more hidden than it did in previous iterations but my mistake! Thanks
Katalon > Test Case > Initially open Test Case > In Script View
Word(s) to the wise…
Take a look at 8.0.0 Alpha release… there’s a ton of prefs changes in there
