Is it possible to specify the Katalon Runtime Engine license location to be different from the default:
root\.katalon\license
I would like to be able to give the new location to the command line interface to specify my own license location.
Thanks!
Thanks!
As my understanding of Activate Katalon Licenses | Katalon Docs, you cannot change the location because it is hidden on purpose, you should not change it
