Katalon crashes and needs to be closed from task manager when this happens, any idea whats going on?
Hi Mark,
Please read this post: http://forum.katalon.com/discussion/4405/read-this-first-before-reporting-an-issue-bug#latest and post your Katalon Studio logs in this case. If you can provide your reproducible steps, it would be nice for us too
Regards
after adding HOME local variable there is still problem opening any project.
the only step i am doing is trying to open a local project.
Windows 10
katalon.versionNumber=5.2.0
katalon.buildNumber=1
!SESSION 2018-01-02 11:27:18.038 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_102
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64 -data config
!ENTRY org.eclipse.core.resources 2 10035 2018-01-02 11:27:23.312
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
Could not find element with Id âcom.kms.katalon.composer.webservice.handledmenuitem.webServiceRequestâ
Could not find element with Id âcom.kms.katalon.composer.mobile.dynamicmenucontribution.iosâ
Warning: NLS unused message: Key in: com.kms.katalon.composer.project.constants.composerProjectMessages
Warning: NLS unused message: Key in: com.kms.katalon.composer.testcase.constants.composerTestcaseMessages
SLF4J: Failed to load class âorg.slf4j.impl.StaticLoggerBinderâ.
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
Warning: NLS unused message: PA_LBL_CREATED_DATE in: com.kms.katalon.composer.testsuite.constants.composerTestsuiteMessages
Warning: NLS unused message: PA_LBL_LAST_UPDATED in: com.kms.katalon.composer.testsuite.constants.composerTestsuiteMessages
Warning: NLS unused message: Key in: com.kms.katalon.composer.objectrepository.constant.composerObjectRepositoryMessages
Warning: NLS unused message: ACTIVATED_PROP_NAME in: com.kms.katalon.constants.messages
Warning: NLS unused message: ACTIVATE_INFO_INVALID in: com.kms.katalon.constants.messages
Warning: NLS unused message: ACTIVATION_CODE_INVALID in: com.kms.katalon.constants.messages
Warning: NLS unused message: ACTIVATION_COLLECT_FAIL_MESSAGE in: com.kms.katalon.constants.messages
Warning: NLS unused message: DIA_TITLE_FUNCTIONS_INTRODUCTION in: com.kms.katalon.constants.messages
Warning: NLS unused message: ERR_CONSOLE_MODE in: com.kms.katalon.constants.messages
Warning: NLS unused message: REQUEST_CODE_PROP_NAME in: com.kms.katalon.constants.messages
Hi Mark,
Based on your provided logs, unfortunately, these logs are not related to your current issue, so Iâm guessing something wrong with the current Katalon Studio. I suggest trying deleting âconfigâ folder from Katalon Studio folder and restart Katalon Studio.
Thanks for the quick answer, Iâm still having this problem after deleting the config folder
This issue persist only on one machine, I was trying to copy a project from a different machine, also was trying to copy the whole Katalon folder from the working machine.
The same issue still persist. tried to re-download Katalon, reboot the machine, nothing helps.
Hi Mark,
Is it possible to share with me your project?
Sure, it will probably work for you, It is working on certain machines - https://drive.google.com/open?id=1tLrtQb3NPXEm14thxbDyR7VH5wMTfJaz
Hi Mark,
Yes you are right. This issue doesnât happen from my side or any other machines from my teammates. Based on your original screenshot, looks like itâs struggling at âIndexing projectâŚâ so I think adding some lines into katalon.ini will work, so can you try adding these lines into katalon.ini file directly:
-clean
-refresh
-XX:+AggressiveOpts
-XX:MinHeapFreeRatio=1
-XX:MaxHeapFreeRatio=2
-XX:+UseSerialGC
Regards
Hi Vinh,
so ivâe tried that with deleteing the config folder and changing
my ini file to look like this but still that didnât work -
-startup
plugins/org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar
âlauncher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.401.v20161122-1740
-data
config
-vmargs
-Xms256m
-Xmx4048m
-clean
-refresh
-XX:+AggressiveOpts
-XX:+UseSerialGC
