I found some similar reports here but they had all been closed after a year of getting no replies.
I am using Katalon for the first time. The three buttons in the START pane (New Project, Open Project and Clone Git Project") are unresponsive, and the “New > Project” menu option is disabled (which is inconsistent with the button, so looks like a bug). Menu options such as “File > New Sample Project > Sample API Tests Project” or “Help > About” are enabled but clicking on them has no effect. I can however close the application.
I am using Katalon 8.4.0 on Ubuntu 18.04, running it from the command line. When I start it up, I get these warnings:
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.codehaus.groovy.reflection.CachedClass (file:/home/PG4341/dev/EVA/Katalon/Katalon_Studio_Linux_64-8.4.0/plugins/org.codehaus.groovy_2.4.20.v202009301404-e2006-RELEASE/lib/groovy-all-2.4.20.jar) to method java.lang.Object.finalize()
WARNING: Please consider reporting this to the maintainers of org.codehaus.groovy.reflection.CachedClass
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Katalon workspace folder is set to default location: /home/PG4341/dev/EVA/Katalon/Katalon_Studio_Linux_64-8.4.0/config
Starting Groovy-Eclipse compiler resolver. Specified compiler level: unspecified
194 org.codehaus.groovy_2.4.20.v202009301404-e2006-RELEASE ACTIVE
WebView Server has been started on port 35017
(Katalon Studio:25513): Gtk-WARNING **: 16:38:42.560: Negative content width -4 (allocation 2, extents 3x3) while allocating gadget (node progressbar, owner GtkProgressBar)
(Katalon Studio:25513): Gtk-WARNING **: 16:38:42.560: Negative content width -2 (allocation 0, extents 1x1) while allocating gadget (node trough, owner GtkProgressBar)
(Katalon Studio:25513): Gtk-WARNING **: 16:38:42.561: Negative content width -4 (allocation 2, extents 3x3) while allocating gadget (node progressbar, owner GtkProgressBar)
(Katalon Studio:25513): Gtk-WARNING **: 16:38:42.561: Negative content width -2 (allocation 0, extents 1x1) while allocating gadget (node trough, owner GtkProgressBar)
