When highlighting mulitple line of code and pressing on the backspace/delete key, Katalon Studio will crash.
Tested ten time with the same use case.
This will happen on:
“feature” file
“.groovy” files
“test case” scripts
OS: IOS
Version: 6.3.3
“feature” file
“.groovy” files
“test case” scripts
OS: IOS
Version: 6.3.3
I have this problem to. You can work around it by deleting your code bit by bit. It isn’t ideal but it will have to do until it’s fixed.
I am having this problem too in MacOS
Katalon version: 6.3.3
Delete small chucks of code
We will release a beta version with Eclipse platform upgraded soon. The new platform will fix this issue. Thank you all for the feedback.
Please try Katalon Studio 8 with Eclipse RCP 4.13.
