Katalon Studio version 6.1.2.rc2 packages
https://s3.amazonaws.com/katalon/release-beta/6.1.2.rc2/Katalon+Studio.dmg
https://s3.amazonaws.com/katalon/release-beta/6.1.2.rc2/Katalon_Studio_Linux_64-6.1.2.tar.gz
https://s3.amazonaws.com/katalon/release-beta/6.1.2.rc2/Katalon_Studio_Windows_32-6.1.2.zip
https://s3.amazonaws.com/katalon/release-beta/6.1.2.rc2/Katalon_Studio_Windows_64-6.1.2.zip
Fixes and Improvements
- Allowed users to disable auto-redirection for API test objects
- Highlighted test steps that call
markFailed - Fixed a bug that caused test cases to fail with status
Reason: BUG! exception in phase 'semantic analysis' in source unit - Showed test case tags in HTML, CSV, and PDF reports
- Added a tab to Search Dialog for searching test objects
- Showed raw data of request and response when executing an API test object
- Made Smart XPath plugin enabled by default
- Fixed a bug that caused the last step to by marked as
failedif any previous steps had failed - Fixed an issue of API testing where POST request JSON Body content is disappeared
Build custom keywords with Settings
With this new feature, a Settings page under Project Settings/Plugins can be created for a custom-keyword plugin. This can be utilized to store project-scoped variables for users to customize.
Add Settings page
Custom Keyword Plugin declares the setting page UI in katalon-plugin.json with this sample:
"keywords": [],
"configuration": {
"settingId": "some id",
"settingPage": {
"name": "name",
"components": [
"key": "key1",
"type": "text",
"label": "My Label 1",
"defaultValue":"My default value 1"
"key": "key2",
"type": "secret",
"label": "My Label 2"
settingId: id the setting file that stores user setting properties in the setting page. There is a file will generated to store user settings at location:
<Project dir>/settings/external/<settingId>.properties -
settingPage : contains the following sub-properties
- name: Name of the setting page
components: list of UI components
- key: key of the component
- label: label of the component
- type: type of the component (‘text’ or ‘secret’)
- defaultValue: default value of the component
Prepare to test
Clone [GitHub - katalon-studio/katalon-studio-excel-keywords-plugin]
Open the project in Katalon Studio at least once
Modify katalon-plugin.json with this template
{ "keywords": ["com.katalon.plugin.keyword.excel.ExcelReadKeywords", "com.katalon.plugin.keyword.excel.ExcelWriteKeywords"], "configuration": { "settingId": "com.katalon.plugin.keyword.excel-keywords", "settingPage": { "name": "Excel Keywords", "components": [ { "key": "username", "type": "text", "label": "Username" }, { "key": "password", "type": "secret", "label": "Password" } ] } } } -
Build excel keyword project
gradle katalonPluginPackageA jar file will be generated in /build/libs folder
Copy and paste the generated jar file to Plugins folder of a Katalon Studio project (Project A)
Open Project A and navigate to Project Settings/Plugins/Excel Keywords
Customize the settings as wish
Retrieve the setting values
The values can be retrieved in keyword script as the following sample:
import com.kms.katalon.core.configuration.RunConfiguration as RunConfiguration
import com.kms.katalon.core.setting.BundleSettingStore as BundleSettingStore
BundleSettingStore bundleSetting = new BundleSettingStore(RunConfiguration.getProjectDir(), '<setting_id>',
true)
println(bundleSetting.getString('username', ''))
println(bundleSetting.getString('password', '')
