Project Settings > Execution > Default is missing the Default execution dropdown that you use to select the default browser. In 5.2.0 Build 1 it was there. In 5.3.0 Build 1 it is missing.
No it is a not a bug. We remove it and now the default execution is the last selected item from your selection to execute a test
Maybe there should be a note about this change in the Release Notes?
Hi Dave,
We’ve noted it here “Auto-saved last execution environment is implemented in Version 5.3 to help save the last selected execution environment as default.” but looks like this is not clear enough. We will adjust it a little bit.
Regards
Thanks Vinh, must have missed that.
In my Katalon Studio, Project Setting -> Execution tab is missing. Can you please help?
Hi! could you please help how to set Browserstack integration in case if Project Setting -> Execution Custom/Default is missing?
It’s moved to Project Settings -> Desired Capabilities -> Default -> Remote
This topic was automatically closed 365 days after the last reply. New replies are no longer allowed.
