Resize Drag Handle
Hey everyone,
so I am testing a web application with Katalon Studio, where I need to have an element resized by using a drag handle.
I already tried the built in Keywords “Drag And Drop by Offset” as well as “Drag And Drop to Element”, both didn’t do the trick.
Also I implemented a custom Keyword for drag n drop HTML5, which is often mentioned in other topics regarding drag n drop functionality with no positive result.
In all cases it marks the step “done” and doesn’t fail but the element is not resized afterwards.
The same element can be moved by drag n drop via another “handle”, which works by using the built in keyword “Drag And Drop By Offset”.
Any help and ideas are appreciated.
Greetings,
Markus
This thread may help you.
Click and hold down mouse button? - Archive - Katalon Community
Thank you for the response, I will look into it =)
This was just added today as well, it may help you more than the last link.
