Saved testobjects have exact same attributes and Katalon doesn't see the ID. Please help
Hello
I’m trying to write a test in which all the checkboxes inside a panel are checked and unchecked in a certain sequence. The problem is that when I save these checkboxes as testobjects every single checkbox gets the exact same tag and xpath.
And here are the attributes:
Naturally the test doesn’t work since Katalon can’t discern the checkboxes because all of them have the same attributes.
I tried manually adding a different ID for each checkbox but if I do that Katalon won’t find the object.
Moreover, if I inspect the elements I can see the ID of the checkbox but Katalon can’t for some reason.
Those first two checkboxes’ ID are incomesource0 and incomesource1 respectively:
Please help. I’m so very stuck in this problem.
Any feedback is much appreciated.
did you try to have just xpath = //input[@id=‘incomeSource0’]?
also you can try to address them using value attribute
please write what you already tried …
Then it’s not correct - and looking at that xpath, I wonder why anyone uses them (confession: I don’t. Ever).
If you use CSS, this is all you need:
#incomesource0
@Andrej_Podhajsky I haven’t tried what you’re saying.
How do I do that? Do I have to change the whole xpath?
Thanks btw!
edit in Object repository what you recorded
leave only xpath checked and change it accordingly
@Russ_Thomas Thanks for replying. I don’t use CSS (at least I don’t think I am). Do I write #income0 in the selector editor? Not quite sure what you mean.
parametrize the test object for the selector, and build the selector in the test script using a template, groovy is smart enough to do substitustions in gstrings, e.g.
my-selector = "#income${index}"
Hello dasu07,
you can use below xpath::
//input[@id = ‘incomeSource0’ and @value=‘Salary’]
//input[@id = ‘incomeSource1’ and @value=‘Pension’]
However you could use the below one also, just another form
//input[@id = ‘incomeSource0’ ]
//input[@id = ‘incomeSource1’]
Let us know if it works or not.
I believe, they should work.
you can see below articles too.
https://www.guru99.com/xpath-selenium.html
https://www.swtestacademy.com/xpath-selenium/
Hello! Thanks for replying.
So… should I replace the entire xpath in the Objext’s xPaths with //input[@id = ‘incomeSource0’ ] for example?
This is how the xpaths look right now. I’m a bit unsure as to where I need to put the value you’re mentioning
It’s in the Selector Editor
Thank you! I changed the xpath in the selector editor but it still doesn’t work for some reason.
My checkbox is located in //button-group/div/label/input/ (?) (see pasted image) but Katalon interprets it when I save the object in //button-group/div/label/i as you can si in the xpath:position value. Do i need to change all the xpaths accordingly or just the selector?
Type this:
#incomesource0
Or…
#incomesource1
“#” means “id”
@dasu07 this can help you to better understand css selectors:
https://www.w3schools.com/cssref/css_selectors.asp
