My code is not working for a drop down value.
WebUI.selectOptionByValue(findTestObject(‘Migration REQ Creation/Page_SID detail (1)/select_-- None --ISM Code Migr’), ‘ISM Code Migration Request’,
true)
This value “ISM Code Migration Request” exists in the drop down field. same code is working for other field though with different object name and value.
I am getting this message
05-15-2018 07:52:25 PM - [FAILED] - Unable to select option by value ‘ISM Code Migration Request’ of object ‘Object Repository/Migration REQ Creation/Page_SID detail (1)/select_-- None --ISM Code Migr’ using regular expression (Root cause: com.kms.katalon.core.webui.exception.WebElementNotFoundException: Web element with id: ‘Object Repository/Migration REQ Creation/Page_SID detail (1)/iframe_gsft_main’ located by ‘By.xpath: //iframe[@src = ‘com.glideapp.servicecatalog_cat_item_view.do?sysparm_catalog=e0d08b13c3330100c8b837659bba8fb4&v=1&sysparm_clear_stack=yes&sysparm_id=955920d1f9ead144cddb5c767d805bb8&sysparm_nameofstack=fddd78564fc2d3c0255b2f6d0210c7c0&sysparm_link_parent=5aff385f1d7ff100b7633835df15e261’ and @name = ‘gsft_main’ and @id = ‘gsft_main’]’ not found)
05-15-2018 07:52:25 PM - [END] - End action : selectOptionByValue
05-15-2018 07:52:25 PM - [END] - End Test Case : Test Cases/ISM L2 catalog item REQ creation
05-15-2018 07:52:25 PM - [FAILED] - Test Cases/ISM L2 catalog item REQ creation FAILED because (of) Unable to select option by value ‘ISM Code Migration Request’ of object ‘Object Repository/Migration REQ Creation/Page_SID detail (1)/select_-- None --ISM Code Migr’ using regular expression (Root cause: com.kms.katalon.core.webui.exception.WebElementNotFoundException: Web element with id: ‘Object Repository/Migration REQ Creation/Page_SID detail (1)/iframe_gsft_main’ located by ‘By.xpath: //iframe[@src = ‘com.glideapp.servicecatalog_cat_item_view.do?sysparm_catalog=e0d08b13c3330100c8b837659bba8fb4&v=1&sysparm_clear_stack=yes&sysparm_id=955920d1f9ead144cddb5c767d805bb8&sysparm_nameofstack=fddd78564fc2d3c0255b2f6d0210c7c0&sysparm_link_parent=5aff385f1d7ff100b7633835df15e261’ and @name = ‘gsft_main’ and @id = ‘gsft_main’]’ not found)
