We’ve been facing issues when running the test suite collection on Jenkins since 6th October 2025, using Katalon Runtime Engine version 8.6.9. Below is the command being executed:
katalonc.sh -noSplash -runMode=console -projectPath=src -browserType="Chrome (headless)" -g_takeScreenshotFlag=false -retry=0 -statusDelay=15 -executionProfile=QA -testSuiteCollectionPath="Test Suites/testSuiteCollection-LMS/assignmentDataCreation_Manual" -licenseRelease=true -apikey=**** -orgID=**** --config -webui.autoUpdateDrivers=false
Start activating offline...
Search for valid offline licenses in folder: /root/.katalon/license
The number of valid offline licenses: 0
Start activating online...
Start release license task
Tue Oct 07 01:31:29 IST 2025
Error when release license
java.lang.NullPointerException
at javax.xml.bind.DatatypeConverterImpl.guessLength(DatatypeConverterImpl.java:654)
at javax.xml.bind.DatatypeConverterImpl._parseBase64Binary(DatatypeConverterImpl.java:692)
at javax.xml.bind.DatatypeConverterImpl.parseBase64Binary(DatatypeConverterImpl.java:434)
at javax.xml.bind.DatatypeConverter.parseBase64Binary(DatatypeConverter.java:342)
at com.kms.katalon.util.CryptoUtil.decode(CryptoUtil.java:86)
at com.kms.katalon.application.utils.ActivationInfoCollector.releaseLicense(ActivationInfoCollector.java:913)
at com.kms.katalon.console.handlers.ActivationHandler.releaseLicense(ActivationHandler.java:197)
at com.kms.katalon.console.handlers.ActivationHandler.activationWithTestOps(ActivationHandler.java:228)
at com.kms.katalon.console.handlers.ActivationHandler.activate(ActivationHandler.java:270)
at com.kms.katalon.console.application.ConsoleMain.launch(ConsoleMain.java:108)
at com.kms.katalon.console.application.ConsoleApplicationStarter.start(ConsoleApplicationStarter.java:36)
at com.kms.katalon.application.Application.runConsole(Application.java:125)
at com.kms.katalon.application.Application.start(Application.java:88)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
Any suggestions on how to resolve this?
