I have been using Katalon all morning and using the execute button on my test collections to run all my tests as I add and refactor them. I have had no issues adding new tests, editing old ones, and running the collection tests up until about 30 minutes ago. I have tried resetting my device and also adding a new test collection with tests in it and still none of my collection tests including the temporary test one in the entire program are working.
I can run test suites and the individual tests with no issues. I have also successfully been able to generate the code for the test collections and run them via command line so the issue lies strictly with the execute button.
I wish I could reproduce what happened but I was editing scripts like I have been the last few weeks and running them the exact same way. When I am on the Console tab and I click Execute in the collection my tab switches to Log Viewer. Log Viewer remains blank though as well as the Console and Problems tabs. I am not getting any errors or anything else.
I would love any advice or steps I can take on my end to help resolve this.
Thank you,
Ricky
Edit: Ok, so I looked around and found the log. This error comes up in Katalon_Studio_Windows_64-5.4.2/config/.metadata/.log file every time that I click the execute button.
!ENTRY org.eclipse.ui 4 0 2018-06-25 15:06:14.267
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.IllegalArgumentException:
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:47)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElementsRecursive(ModelServiceImpl.java:145)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:394)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:380)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.find(ModelServiceImpl.java:413)
at com.kms.katalon.composer.execution.handlers.AbstractExecutionHandler$3.run(AbstractExecutionHandler.java:365)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4821)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at com.kms.katalon.composer.execution.handlers.AbstractExecutionHandler.openConsoleLog(AbstractExecutionHandler.java:337)
at com.kms.katalon.composer.testsuite.collection.part.TestSuiteCollectionPart.executeTestRun(TestSuiteCollectionPart.java:659)
at com.kms.katalon.composer.testsuite.collection.part.provider.ToolbarItemListener.executeTestRun(ToolbarItemListener.java:88)
at com.kms.katalon.composer.testsuite.collection.part.provider.ToolbarItemListener.executeAction(ToolbarItemListener.java:73)
at com.kms.katalon.composer.testsuite.collection.part.provider.ToolbarItemListener.widgetSelected(ToolbarItemListener.java:50)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at com.kms.katalon.core.application.Application.internalRunGUI(Application.java:115)
at com.kms.katalon.core.application.Application.runGUI(Application.java:100)
at com.kms.katalon.core.application.Application.start(Application.java:60)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
