Brandon, thank you for this util sample. This static approach I am also going to use it for my projects tomorrow
Wow! @Brandon_Hein I see that you perceived clearly when I said ânever programmed in javaâ. Thanks for the very clear instructions. Thanks @Russ_Thomas for clarifying as well. Before trying Brendonâs keyword solution, I used the âself containedâ solution (I hate saying the word method here as it really confuses things) which did successfully get to that button that was hidden under some other object(s). Commented out that and then tried with my new keyword in my util package.
Unfortunately, Katalon doesnât seem to find the method executeJavaScript() as it spits this back to me.
groovy.lang.MissingMethodException: No signature of method: static com.kms.katalon.core.webui.keyword.WebUiBuiltInKeywords.executeJavaScript()
and then points to line 13 of the Util.groovy: WebUI.executeJavaScript(âarguments[0].click();â, element);
Yea, the WebUI API can be troublesome at times (or Iâm just using it incorrectly). Since the approach in my original comment seemed to work for you, we can just use that. Itâs a bit more verbose, but not too bad. Go ahead and replace your Util class with this:
package util
import org.openqa.selenium.JavascriptExecutor
import org.openqa.selenium.WebDriver
import org.openqa.selenium.WebElement
import com.kms.katalon.core.testobject.TestObject
import com.kms.katalon.core.webui.common.WebUiCommonHelper
import com.kms.katalon.core.webui.driver.DriverFactory
public class Util {
public static void jsClick(final TestObject testObject) {
WebElement element = WebUiCommonHelper.findWebElement(testObject, 30);
WebDriver driver = DriverFactory.getWebDriver();
JavascriptExecutor jsExecutor = (JavascriptExecutor)driver;
jsExecutor.executeScript("arguments[0].click();", element);
I ran this on my side as well to be sure, should work fine
Iâve updated the demo I gave above to match this.
Side note: A âmethodâ in Java is analogous to a âfunctionâ in C/JavaScript/etc. Itâs just a set of code you can call to do some chunk of work for you.
YES Excellent. Just about to leave the office and bing, it works. BIG thanks Brendon and Russ.
Curtis
Glad to help
Hello, Iâm a beginner, thank you all for your contributions. Iâve also the same problem. Iâts a greatful tips
Hi @Brandon_Hein,
I have tried your solution to click in a toggle button, but the script stops in those steps (it doesnât fail) and I see that the button is not clicked.
Any suggestion?
Thanks,
Ruben B
You should make sure the buttton is present and is clickable before you actually click it.
There are a few Katalon build-in keywords to wait for element. For example, you can do:
TestObject myTestObject = ObjectRepository.findTestObject("Page_Acronyms and Terms Insider/span_My Acronyms");
// wait for the element to appear
WebUI.verifyElementPresent(myTestObject, 10)
// then click it
Util.jsClick(myTestObject)
If you prefer Selenium WebDriver native approach, the following post may be informative:
Hi @kazurayam,
Thanks for the info. I found the below js that worked
import org.openqa.selenium.WebDriver as WebDriver
import org.openqa.selenium.WebElement as WebElement
import org.openqa.selenium.interactions.Actions as Actions
import com.kms.katalon.core.webui.common.WebUiCommonHelper as WebUiCommonHelper
import com.kms.katalon.core.webui.driver.DriverFactory as DriverFactory
import org.openqa.selenium.JavascriptExecutor as JavascriptExecutor
import com.kms.katalon.core.annotation.Keyword
@Keyword
def clickUsingJS(TestObject to, int timeout) {
WebElement element = WebUiCommonHelper.findWebElement(to, timeout)
JavascriptExecutor executor = ((driver) as JavascriptExecutor)
executor.executeScript(âarguments[0].click()â, element)
in the script:
CustomKeywords.âClickJS.clickUsingJSâ(findTestObject(âPage_Acronyms and Terms Insider/span_My Acronymsâ), 30)
Thanks,
Ruben B
Thanks a lot
