Hi Peeps,
I’m getting an error ‘Unable to close current project’. As a result, the project is not available when I open katalon studio nor available in recent project list.
logs: KS/congif/.metadata/.log
!ENTRY org.eclipse.e4.ui.workbench 4 0 2019-09-10 11:23:33.470
!MESSAGE
!STACK 0
com.kms.katalon.composer.project.exception.MissingProjectSettingPageException: Project Settings page ID ‘com.kms.katalon.composer.execution.settings.default’ not found.
at com.kms.katalon.composer.project.handlers.SettingHandler.hideIOSPageOnNoneMacOS(SettingHandler.java:295)
at com.kms.katalon.composer.project.handlers.SettingHandler.openSettingsDialogToPage(SettingHandler.java:152)
at com.kms.katalon.composer.project.handlers.SettingHandler.execute(SettingHandler.java:84)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:282)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:488)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:433)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:454)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem$3.handleEvent(AbstractContributionItem.java:482)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at com.kms.katalon.core.application.Application.internalRunGUI(Application.java:154)
at com.kms.katalon.core.application.Application.runGUI(Application.java:144)
at com.kms.katalon.core.application.Application.start(Application.java:74)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
Warning: NLS unused message: MENU_CONTEXT_WEBSERVICE_REQ_POSTMAN in: com.kms.katalon.composer.webservice.constants.composerWebserviceMessages
2019-09-10 11:26:24.256:INFO::main: Logging initialized @385091ms to org.seleniumhq.jetty9.util.log.StdErrLog
Launcher status after execution process completed: Running
!ENTRY org.eclipse.core.resources 2 10035 2019-09-10 11:27:32.051
!MESSAGE The workspace will exit with unsaved changes in this session.
machine-id=XXXXXXXXXXXXXXXXXXXXXXX
katalon.versionNumber=6.3.4
katalon.buildNumber=1
!SESSION 2019-09-10 11:38:57.488 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_181
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_AU
Command-line arguments: -os win32 -ws win32 -arch x86_64 -data @noDefault
!ENTRY org.eclipse.core.resources 2 10035 2019-09-10 11:39:00.096
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
Could not find element with Id ‘com.kms.katalon.composer.webservice.handledmenuitem.webServiceRequest’
Could not find element with Id ‘katalon.composer.objectrepository.handledmenuitem.spyweb’
Could not find element with Id ‘com.kms.katalon.composer.mobile.dynamicmenucontribution.ios’
Warning: NLS unused message: Key in: com.kms.katalon.composer.project.constants.composerProjectMessages
Warning: NLS unused message: Key in: com.kms.katalon.composer.testcase.constants.composerTestcaseMessages
Warning: NLS missing message: BTN_ADDTESTSUITE in: com.kms.katalon.composer.testcase.constants.composerTestcaseMessages
Warning: NLS unused message: PA_LBL_CREATED_DATE in: com.kms.katalon.composer.testsuite.constants.composerTestsuiteMessages
Warning: NLS unused message: PA_LBL_LAST_UPDATED in: com.kms.katalon.composer.testsuite.constants.composerTestsuiteMessages
Warning: NLS unused message: Key in: com.kms.katalon.composer.objectrepository.constant.composerObjectRepositoryMessages
Warning: NLS missing message: MSG_FORUM_SEARCH in: com.kms.katalon.constants.messages
!ENTRY org.eclipse.egit.ui 2 0 2019-09-10 11:39:07.838
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: ‘C:\Users\pdave’. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
log4j:WARN No appenders could be found for logger (org.apache.http.client.protocol.RequestAuthCache).
log4j:WARN No appenders could be found for logger (org.apache.http.client.protocol.RequestAddCookies).
log4j:WARN Please initialize the log4j system properly.
!ENTRY org.eclipse.jface 2 0 2019-09-10 11:39:25.326
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2019-09-10 11:39:25.326
!MESSAGE A conflict occurred for CTRL+SHIFT+D:
Binding(CTRL+SHIFT+D,
ParameterizedCommand(Command(org.eclipse.jdt.debug.ui.commands.Display,Display,
Display result of evaluating selected text,
Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Debug command category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@6e43c01f,
,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.dialogAndWindow,system)
ParameterizedCommand(Command(com.kms.katalon.composer.execution.command.debug,
Debug,
Category(org.eclipse.e4.ui.model.application.MApplication,Application Category,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@a93c798,
[Parameter(com.kms.katalon.composer.execution.runMode,Run Mode,null,true)],true),[org.eclipse.core.commands.Parameterization@de6e4672]),
org.eclipse.ui.contexts.dialogAndWindow ,system)
Warning: NLS unused message: Key in: com.kms.katalon.composer.webui.constants.composerWebuiMessages
Warning: NLS missing message: DIA_CONFIRM_INSTALL_WEBDRIVER in: com.kms.katalon.composer.webui.constants.composerWebuiMessages
Warning: NLS missing message: DIA_CONFIRM_INSTALL_WEBDRIVER_TITLE in: com.kms.katalon.composer.webui.constants.composerWebuiMessages
