Hi, Since Google Less secure apps is not supported now I am unable to connect my email with the App Password here is my setting
As observing here Share test reports via email in Katalon Studio | Katalon Docs, I guess you should try “Protocol - TLS” instead of “SSL”. Hope help!
Already tried the TLS also but still not working
As observing here https://docs.katalon.com/docs/analyze/reports/manage-reports/share-test-reports-via-email-in-katalon-studio, I guess you should try “Protocol - TLS” instead of “SSL”. Hope help!
Hi @Elly_Tran its still the same
@Elly_Tran Its been weeks since your last reply. any update on this matter?
Let me discuss internally whether this is bug or not. Get back to you soon
Hi @Elly_Tran Any update?
Can you try the port 587? I have tried it successfully.
Hi @Elly_Tran! Am facing a similar issue here with Katalon version 8.6.0. These below are my configurations for Outlook
And this is the error I keep getting.
I’ve tried using SSL and None under “Protocol”, I’ve also tried with Port 25 as per the documentation, I’ve also tried to configure with Gmail and Yahoo, but that error message persists and emails do not come through still.
Any ideas?
