I installed a Katalon Studio trial several months ago and after installation it never worked. I recently dowloaded an updated version of the trial hoping the issues would be resolved but they are not. When ever I launch Katalon Studio, I see a message like this:
The log reads as follows, but is far longer (90K+ characters) than will fit in a post on this forum.
This application remains untestable. I don’t understand how and the installation procedure should be any harder than installing a regular Mac app.
These are the last 100 lines of the log file which presumably contain the error.
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.718
!MESSAGE Could not install bundle plugins/org.apache.commons.codec_1.7.0.jar A bundle is already installed with the name “org.apache.commons.codec” and version “1.7.0”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.722
!MESSAGE Could not install bundle plugins/org.codehaus.groovy.eclipse.refactoring_2.9.2.xx-201611170128-e46.jar A bundle is already installed with the name “org.codehaus.groovy.eclipse.refactoring” and version “2.9.2.xx-201611170128-e46”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.724
!MESSAGE Could not install bundle plugins/com.fasterxml.jackson.dataformat.jackson-dataformat-xml_2.9.1.jar A bundle is already installed with the name “com.fasterxml.jackson.dataformat.jackson-dataformat-xml” and version “2.9.1”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.727
!MESSAGE Could not install bundle plugins/org.w3c.dom.events_3.0.0.draft20060413_v201105210656.jar A bundle is already installed with the name “org.w3c.dom.events” and version “3.0.0.draft20060413_v201105210656”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.729
!MESSAGE Could not install bundle plugins/com.kms.katalon.core.webservice_1.0.0.201908270734.jar A bundle is already installed with the name “com.kms.katalon.core.webservice” and version “1.0.0.201908270734”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.734
!MESSAGE Could not install bundle plugins/org.eclipse.core.filebuffers_3.6.0.v20160503-1849.jar A bundle is already installed with the name “org.eclipse.core.filebuffers” and version “3.6.0.v20160503-1849”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.736
!MESSAGE Could not install bundle plugins/com.kms.katalon.support.testing.katserver_1.0.0.201908270734.jar A bundle is already installed with the name “com.kms.katalon.support.testing.katserver” and version “1.0.0.201908270734”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.739
!MESSAGE Could not install bundle plugins/org.eclipse.e4.ui.model.workbench_1.2.0.v20160229-1459.jar A bundle is already installed with the name “org.eclipse.e4.ui.model.workbench” and version “1.2.0.v20160229-1459”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.743
!MESSAGE Could not install bundle plugins/org.eclipse.swt.cocoa.macosx.x86_64_3.105.3.v20170228-0512.jar A bundle is already installed with the name “org.eclipse.swt.cocoa.macosx.x86_64” and version “3.105.3.v20170228-0512”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.746
!MESSAGE Could not install bundle plugins/org.codehaus.groovy.eclipse.ui_2.9.2.xx-201611170128-e46.jar A bundle is already installed with the name “org.codehaus.groovy.eclipse.ui” and version “2.9.2.xx-201611170128-e46”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.748
!MESSAGE Could not install bundle plugins/com.kms.katalon.util_1.0.0.201908270734.jar A bundle is already installed with the name “com.kms.katalon.util” and version “1.0.0.201908270734”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.750
!MESSAGE Could not install bundle plugins/com.kms.katalon.integration.jira_1.0.0.201908270734.jar A bundle is already installed with the name “com.kms.katalon.integration.jira” and version “1.0.0.201908270734”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.752
!MESSAGE Could not install bundle plugins/org.greenrobot.eventbus_3.1.1.jar A bundle is already installed with the name “org.greenrobot.eventbus” and version “3.1.1”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.755
!MESSAGE Could not install bundle plugins/org.eclipse.core.databinding.observable_1.6.0.v20160511-1747.jar A bundle is already installed with the name “org.eclipse.core.databinding.observable” and version “1.6.0.v20160511-1747”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.757
!MESSAGE Could not install bundle plugins/com.kms.katalon.composer.preferences_1.0.0.201908270734.jar A bundle is already installed with the name “com.kms.katalon.composer.preferences” and version “1.0.0.201908270734”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.758
!MESSAGE Could not install bundle plugins/com.kms.katalon.composer.objectrepository_1.0.0.201908270734.jar A bundle is already installed with the name “com.kms.katalon.composer.objectrepository” and version “1.0.0.201908270734”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.760
!MESSAGE Could not install bundle plugins/com.kms.katalon.platform.internal_1.0.0.201908270734.jar A bundle is already installed with the name “com.kms.katalon.platform.internal” and version “1.0.0.201908270734”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.762
!MESSAGE Could not install bundle plugins/org.eclipse.compare_3.7.1.v20170103-1805.jar A bundle is already installed with the name “org.eclipse.compare” and version “3.7.1.v20170103-1805”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.764
!MESSAGE Could not install bundle plugins/com.mysql.jdbc_5.1.38.jar A bundle is already installed with the name “com.mysql.jdbc” and version “5.1.38”
!ENTRY org.eclipse.update.configurator 4 0 2019-11-10 15:31:28.765
!MESSAGE Could not install bundle plugins/javax.annotation_1.2.0.v201602091430.jar A bundle is already installed with the name “javax.annotation” and version “1.2.0.v201602091430”
!ENTRY org.eclipse.osgi 4 0 2019-11-10 15:31:30.111
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: The platform metadata area could not be written: /private/var/folders/j1/kxnsbb1x71j29zv2l21cj32446bpq5/T/AppTranslocation/F8A5CEE1-1EF7-4CDA-805C-8BEDBB15B8C4/d/Katalon Studio.app/Contents/MacOS/config/.metadata. By default the platform writes its content
under the current working directory when the platform is launched. Use the -data parameter to
specify a different content area for the platform.
at org.eclipse.core.internal.runtime.DataArea.assertLocationInitialized(DataArea.java:61)
at org.eclipse.core.internal.runtime.DataArea.getStateLocation(DataArea.java:129)
at org.eclipse.core.internal.preferences.InstancePreferences.getBaseLocation(InstancePreferences.java:44)
at org.eclipse.core.internal.preferences.InstancePreferences.initializeChildren(InstancePreferences.java:209)
at org.eclipse.core.internal.preferences.InstancePreferences.(InstancePreferences.java:59)
at org.eclipse.core.internal.preferences.InstancePreferences.internalCreate(InstancePreferences.java:220)
at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:352)
at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:340)
at org.eclipse.core.internal.preferences.PreferencesService.createNode(PreferencesService.java:391)
at org.eclipse.core.internal.preferences.RootPreferences.getChild(RootPreferences.java:60)
at org.eclipse.core.internal.preferences.RootPreferences.getNode(RootPreferences.java:95)
at org.eclipse.core.internal.preferences.RootPreferences.node(RootPreferences.java:84)
at org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractScope.java:38)
at org.eclipse.core.runtime.preferences.InstanceScope.getNode(InstanceScope.java:77)
at com.kms.katalon.preferences.internal.ScopedPreferenceStore.getStorePreferences(ScopedPreferenceStore.java:216)
at com.kms.katalon.preferences.internal.ScopedPreferenceStore.(ScopedPreferenceStore.java:117)
at com.kms.katalon.preferences.internal.PreferenceStoreManager.initialPreferenceStore(PreferenceStoreManager.java:25)
at com.kms.katalon.preferences.internal.PreferenceStoreManager.getPreferenceStore(PreferenceStoreManager.java:21)
at com.kms.katalon.preferences.internal.PreferenceStoreManager.getPreferenceStore(PreferenceStoreManager.java:14)
at com.kms.katalon.util.ApplicationSession.getStore(ApplicationSession.java:47)
at com.kms.katalon.util.ApplicationSession.clean(ApplicationSession.java:16)
at com.kms.katalon.core.application.Application.preRunInit(Application.java:114)
at com.kms.katalon.core.application.Application.start(Application.java:60)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
