Hi, I’m not able to select a string in the dropdown list. I’ve tried with the Select option by label/index. Please see the screenshot for the information.
I am sure if you search the forum you will find a lot of answers you can try.
For example:
You need to check first if the tag is a select in your html.
At the top of your error message, it says you are not using a “select” for your drop-down. The selectOptionByLabel(), selectOptionByValue() and selectOptionByIndex() work on a select tag. Either show us your HTML to better assist you or revisit your HTML and determine the appropriate means for your drop-down.
This may assist you on viewing the HTML:
