Unable to start application in android devices
please solve this error, unable to start application in mobile devices
Kindly post the error trace in a formatted way for better readability instead of image
from above, appium driver compatibility issue. kindly upgrade your KS version along with appium drivers
halo dineshh, my KS latest version and appium latest version. Currently, I am still experiencing the same error.
2025-07-10 13:40:33.843 ERROR c.k.k.core.keyword.internal.KeywordMain - :cross_mark: Unable to start application: ‘/Users/irfanmaulana/Downloads/app-uat-cakra-v5.3.6-rc3-173-300625.apk’ (Root cause: com.kms.katalon.core.exception.StepFailedException: Unable to start application: ‘/Users/irfanmaulana/Downloads/app-uat-cakra-v5.3.6-rc3-173-300625.apk’
at com.kms.katalon.core.mobile.keyword.internal.MobileKeywordMain.stepFailed(MobileKeywordMain.groovy:65)
at com.kms.katalon.core.mobile.keyword.internal.MobileKeywordMain.runKeyword(MobileKeywordMain.groovy:34)
at com.kms.katalon.core.mobile.keyword.builtin.StartApplicationKeyword.startApplication(StartApplicationKeyword.groovy:91)
at com.kms.katalon.core.mobile.keyword.builtin.StartApplicationKeyword.execute(StartApplicationKeyword.groovy:48)
at com.kms.katalon.core.keyword.internal.KeywordExecutor.executeKeywordForPlatform(KeywordExecutor.groovy:64)
at com.kms.katalon.core.mobile.keyword.MobileBuiltInKeywords.startApplication(MobileBuiltInKeywords.groovy:50)
at scn01.run(scn01:24)
at com.kms.katalon.core.main.TestCaseExecutor.runScript(TestCaseExecutor.java:485)
at com.kms.katalon.core.main.TestCaseExecutor.doExecute(TestCaseExecutor.java:476)
at com.kms.katalon.core.main.TestCaseExecutor.processExecutionPhase(TestCaseExecutor.java:455)
at com.kms.katalon.core.main.TestCaseExecutor.accessMainPhase(TestCaseExecutor.java:447)
at com.kms.katalon.core.main.TestCaseExecutor.execute(TestCaseExecutor.java:321)
at com.kms.katalon.core.main.TestCaseMain.runTestCase(TestCaseMain.java:151)
at com.kms.katalon.core.main.TestCaseMain.runTestCase(TestCaseMain.java:139)
at TempTestCase1752129629317.run(TempTestCase1752129629317.groovy:25)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
Caused by: org.openqa.selenium.SessionNotCreatedException: Could not start a new session. Response code 500. Message: An unknown server-side error occurred while processing the command. Original error: The application at ‘/Users/irfanmaulana/Downloads/app-uat-cakra-v5.3.6-rc3-173-300625.apk’ does not exist or is not accessible
Host info: host: ‘MDTMAC688823958.local’, ip: ‘fe80:0:0:0:99:40ee:7d12:794e%en0’
Build info: version: ‘4.28.1’, revision: ‘73f5ad48a2’
System info: os.name: ‘Mac OS X’, os.arch: ‘aarch64’, os.version: ‘14.7.4’, java.version: ‘17.0.14’
Driver info: io.appium.java_client.android.AndroidDriver
Command: [null, newSession {capabilities=[Capabilities {appium:app: /Users/irfanmaulana/Downloa…, appium:autoGrantPermissions: true, appium:automationName: uiautomator2, appium:deviceId: 2419d054921c7ece, appium:deviceName: samsung SM-N960F (Android 10), appium:fullReset: true, appium:newCommandTimeout: 1800, appium:noReset: false, appium:platformName: ANDROID, appium:platformVersion: 10, appium:systemPort: 61022, appium:udid: 2419d054921c7ece, platformName: ANDROID}]}]
at org.openqa.selenium.remote.ProtocolHandshake.createSession(ProtocolHandshake.java:114)
at org.openqa.selenium.remote.ProtocolHandshake.createSession(ProtocolHandshake.java:75)
at org.openqa.selenium.remote.ProtocolHandshake.createSession(ProtocolHandshake.java:61)
at io.appium.java_client.remote.AppiumCommandExecutor.createSession(AppiumCommandExecutor.java:176)
at io.appium.java_client.remote.AppiumCommandExecutor.execute(AppiumCommandExecutor.java:237)
at org.openqa.selenium.remote.RemoteWebDriver.execute(RemoteWebDriver.java:545)
at io.appium.java_client.AppiumDriver.startSession(AppiumDriver.java:270)
at org.openqa.selenium.remote.RemoteWebDriver.(RemoteWebDriver.java:174)
at io.appium.java_client.AppiumDriver.(AppiumDriver.java:91)
at io.appium.java_client.android.AndroidDriver.(AndroidDriver.java:99)
at com.kms.katalon.core.appium.driver.AppiumDriverManager.createMobileDriver(AppiumDriverManager.java:574)
at com.kms.katalon.core.appium.driver.AppiumDriverManager.createMobileDriver(AppiumDriverManager.java:551)
at com.kms.katalon.core.mobile.keyword.internal.MobileDriverFactory.startLocalMobileDriver(MobileDriverFactory.java:604)
at com.kms.katalon.core.mobile.keyword.internal.MobileDriverFactory.startMobileDriver(MobileDriverFactory.java:511)
at com.kms.katalon.core.mobile.keyword.builtin.StartApplicationKeyword$_startApplication_closure1.doCall(StartApplicationKeyword.groovy:89)
at com.kms.katalon.core.mobile.keyword.builtin.StartApplicationKeyword$_startApplication_closure1.call(StartApplicationKeyword.groovy)
at com.kms.katalon.core.mobile.keyword.internal.MobileKeywordMain.runKeyword(MobileKeywordMain.groovy:30)
at Script1750826449136.run(Script1750826449136.groovy:24)
… 13 more
2025-07-10 13:40:33.846 ERROR c.k.katalon.core.main.TestCaseExecutor - :cross_mark: Test Cases/Test/scn01 FAILED.
… 18 more
… 13 more
… 18 more
kindly format the code for better readability. use ``` followed by your code
error indicates that Appium/Katalon cannot find your APK file at the specified path.
  1. Path does not exist in CI environment:
    /Users/irfanmaulana/Downloads/ is your local macOS path. Your GitLab runner (likely Windows-based) doesn’t have this path.
  2. File accessibility issues:
    Even if the file exists, Appium might lack permissions to access it.
  3. Path handling differences:
    Windows paths use backslashes (\) while macOS uses forward slashes (/)
Solution: Fix APK Path Handling
Step 1: Make APK available in CI
text
test_katalon_mobile:
  stage: test
  artifacts:
    paths:
      - apps/
  script:
    # Download APK to project-relative path
    - mkdir apps
    - curl -o apps/app.apk https://your-artifact-repository/app-uat-cakra-v5.3.6-rc3-173-300625.apk
    # Verify download
    - dir apps\  # Windows
    # OR
    - ls -l apps/  # macOS/Linux
Step 2: Update Katalon Configuration
text
- & "C:\Program Files\Katalon_Studio_Engine_Windows_64-10.2.3\katalonc.exe"
    # Use relative path
    -g_APP_PATH="apps/app.apk"
Step 3: Modify Your Test Script
In Katalon test case:
groovy
// Use GlobalVariable for path
String appPath = GlobalVariable.APP_PATH ?: "/Users/irfanmaulana/Downloads/app.apk"
Mobile.startApplication(appPath, false)
Alternative Solutions
Option 1: Absolute Path (For Dedicated Runners)
text
variables:
  APK_PATH: "C:\\gitlab-runner\\apps\\app.apk"
script:
  - & katalonc.exe ... -g_APP_PATH="${APK_PATH}"
Option 2: Network Share (For Private Runners)
text
script:
  - net use Z: \\server\apps /user:user pass
  - & katalonc.exe ... -g_APP_PATH="Z:\\app.apk"
Critical Checks
  1. File Existence Verification
    Add this to your CI script:
bash
# Windows
if not exist "apps\app.apk" (echo "APK missing!" && exit 1)
# macOS/Linux
[ -f "apps/app.apk" ] || (echo "APK missing!" && exit 1)
  1. Appium File Access
    Add this capability to your mobile profile:
javascript
"appium:allowTestPackages": true,
"appium:enforceAppInstall": true
  1. Path Format Conversion
text
- sed -i 's/\/Users\/irfanmaulana\/Downloads\//apps\//g' your_test_case.groovy
Final .gitlab-ci.yml Snippet
text
  stage: test
  tags:
    - runner_for_mobile
  variables:
    APK_URL: "https://artifacts.example.com/app.apk"
    APK_PATH: "apps/app.apk"
  before_script:
    - mkdir apps
    - curl -o "${APK_PATH}" "${APK_URL}"
  script:
    - adb devices
        -noSplash
        -runMode=console
        -projectPath="C:\path\to\project.prj"
        -testSuitePath="Test Suites/Auth/Login"
        -browserType="Android"
        -deviceId="9ff68ebd"
        -executionProfile="default"
        -g_APP_PATH="${APK_PATH}"  # Critical injection
        -appiumDirectory="C:\Program Files\Appium"
Verification Steps
  1. Check pipeline artifacts for downloaded APK
  2. Add pipeline step: cat apps/app.apk | head -c 10 (should show PK header)
  3. Enable Appium logs:
text
- appium --log-level debug > appium.log 2>&1 &
- cat appium.log | grep 'path.*app.apk'
