I’m unable to open any of the existing projects in katalon. I have 9.5 version. when I try to open, I get the below error :
Kindly help. Thanks in advance
Hi there, ![]()
Thank you very much for your topic! It may take a little while before Katalon team member or others forum members respond to you.
In the meantime, you can double-check your post to see if you can add any extra information i.e. error logs, HTML codes, screenshots, etc. Check out this posting guide to help us help you better!
Thanks! ![]()
Katalon Community team
Do you accidentally delete the project as it said: No project found?
A similar discussion is here: Katalon studio project non found - #4 by simona.megna. Please take a look! Let me know if it works.
